Hi guys,
I need to get a small piece of pre-resined carbon sheeting. It must be real carbon. dont want any coloured weave, just the regular black/grey weave is fine. Could possibly buy some weave then just do the layers and resin myself but i'd prefer pre-fab. It's just to fill a hole in the centre console and will then use it to mount some switches etc.
Any help pointing me in the right direction would be much appreciated.
Richard
  • Replies 46
Posted Images
We've got some... bought off a supplier in Brookvale. If you want I'll get you the supplier details, otherwise tell me what size you want and I'll see if I can find some offcuts.
exactly like that! only just black/grey CF instead of kevlar weave, and also half that size (replacing the 3 gauge cluster).
but i'll take kevlar weave in a pinch if someone had some lying around (hint paul!). :D
i left some at Croydon's...ill ring em and see if its still there...ok
i'm excited. i'm going to use that space to mount the defi link controller and the dirtgarage D1 edition awd switch. and maybe relocate the ultra speed meter there too.
If that falls through, try going to a boat building place, there are a few around that make the sydney to hobart boats... We used to get their 'offcuts' to make our body work for a little SAE car. Cant remember who we used last year but its worth a shot, not something that comes to mind at first though is it!!
Do you have an oven? remember the pre-preg stuff needs baking!!
thank mate, yep i do have an oven. but i think a flat sheet that has already been laid and coated wont need any more prep work. just drill my holes and bolt it in.
Ahh yep, sorry i didnt realise it was just going to be a flat sheet that you want.
Good luck with it, post pics for general interest when you are done?
I am about to go to CRD myself, been speaking with a bloke called Jim, i need a few things done to my car. Hopefully within the next few days, things keep getting put on hold for me. I just want my car fixed, running nicely and back on the road
thanks for the kind offer Aaron. I'm going to chase up a lead tomorrow morning, but if they haven't got what i need i may take you up on that. we have some resin left and i guess i could just buy some regular fibreglass weave to make it 1 layer CF, 2 layer fibre...
I will let you know :P
BB
i may have sum left over if you want it, its only thin tho (1mm) carbon weave , guess can glue it to 2mm perspex to make it thicker, so yeh let me know if you need it.
aaron
Hi Aaron, if BB doesn't need it, I will take it. I need to replace a gauge panel and a POD heat shield cover so 1mm would be perfect. What are the dimensions?
:P cheers :D
Biatch,
There's a place in the same complex as UAS that does custom carbon fibre work... They were working on this 100% carbon fibre body race car the last time I dropped by.
The guy is very eccentric, but he does amazing work. He made custom sized sheets for this exact application for me a few years ago... Very cheap too. From memory I got him to do 3 layers of carbon (ended up being about 3mm thick and BLOODY STRONG), and a gloss top coat in double-din size, and it cost me about $30-40.
Can't remember the shop number, but I think the guy's name was Alan. John will remember the guy if you ask him.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
