  • Replies 46
Posted Images
Biatch,
There's a place in the same complex as UAS that does custom carbon fibre work... They were working on this 100% carbon fibre body race car the last time I dropped by.
The guy is very eccentric, but he does amazing work. He made custom sized sheets for this exact application for me a few years ago... Very cheap too. From memory I got him to do 3 layers of carbon (ended up being about 3mm thick and BLOODY STRONG), and a gloss top coat in double-din size, and it cost me about $30-40.
Can't remember the shop number, but I think the guy's name was Alan. John will remember the guy if you ask him.
Carbon Artistry
U20/ 2a Victoria Ave Castle Hill 2154 (02) 9894 8337
Thats where im getting my stuff done from Richard.......and as Andrew says he is a litle eccentric but his work is very good !!
Hi Aaron, if BB doesn't need it, I will take it. I need to replace a gauge panel and a POD heat shield cover so 1mm would be perfect. What are the dimensions?
:rofl: cheers ;)
np...ive got just i think enuff to fit din size across and have another piece thats bit bigger...also have the carbon fibre weave..if u or BB knows how to resin it up into sheets i can cut sum up for u 2 and you guys can go from there. aaron
thanks guys. SK can have the weave as i got a small piece from John acutally. But i may ring carbon artistry too and see if i can get some more. thanks andrew and thomas :)
Carbon Artistry
Thats where im getting my stuff done from Richard.......and as Andrew says he is a little eccentric but his work is very good !!
.....just a tad!
Hes a really nice guy, but yes, quirky to say the least
  • 3 weeks later...
thanks for the tip on carbon artistry guys, but thomas if you are 'getting stuff done' there i hope it's already been finished as they closed up shop for good today. he packed up the shop and is moving on to something not related to fibre work. :D
http://www.hpi.co.jp/nlineupflatpanels.html
Dry Carbon starts 6th row down the left.
Read: Dry Carbon -> Size -> Thickness -> Price -> Price including Japanese Sales Tax -> Notes
We are also now authorised distributors for HPI products in Australia
Does anyone know where to get this stuff aswel out of interest? (locally)
Ive been told plumbing stores, and tried 2 today without luck
Ducting
That looks like the stuff someone would use as an air conditioning duct or a skylight duct. Small tho. I got something that looks similar to that and made an air duct/passage from the front of my Celica to the air box.
Got it from Bunnings in the plumbing section i think it was.
Thanks, but thats one of the places i went to - they didnt know anything about it :D
Ill keep on looking around
Cheers
holy smokes batman! that is some serious yen.
adrian the stuff on the forum is pre-preg sheet. the stuff tosh is showing/selling is pre fabricated carbon sheets. the differnce is pre-preg is just the raw carbon/fibre weave and needs shaping and then a resin applied. the sheets from HPI are formed dry carbon pieces made by a different methond to 'wet laying' of pre-preg.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
