Theres not much you can do with the standard box.
maybe if you have a FMIC, you can use the holes from the standard SMIC to run a pipe directly into the box.
I have a GTT with the standard SMIC and hav a pod with custom box that uses the standard snorkel.
looks good and is more effective because pod is not as restrictive as panel filter.
I have the same Nismo panel filter and have 255rwkw at 0.9 bar so it's not restrictive. The bonnet may be an issue though. I am waiting for an opportunity to do a power run with bonnet down as I think there may be some restriction there. Not sure.
I have got plans for when I get a cf bonnet. I will be making a hole just behind the headlight with an electrically operated sliding flap and a duct to the front of the airbox. The flap will be operated by an electric door lock actuator and controlled from in the cabin.
