hi guys,
i have just written off my 1998 celica after some clown failed to stop at a roundabout and slammed into my left side at 70km/h. I have been planning to get something else for the past year cause i just started getting sick of the power, or lack there of, of the celica. Dont get me wrong they're a great sports car and extremely reliable (I thrashed that thing so f*@ken bad), but i just got over it. Great for a first car tho.
So after the accident the first thing i did when i got back from the hospital :P was get on carsales.com and start lookin for a new car.
My budget is around $27k. My first thoughts were supra. I have admired these beasts of a car since i was 12. Luv the looks, luv the power and torque especially (very important), but nowadays they're just so old!! most examples in aus are atleast 12 years old with plenty of kays. i have also neva been in one. All my knowledge for them has come from mates, mags and the net.
My otha option is an R34 GTT. After i took a ride in my mates one, i fell in love. It had a nismo b/kit, full exhaust and the rest was stock but i still loved the power, the response, the looks and interior of the thing. they're both at a similar price but with the supra its a much older car with much more kays.
What would you guys do?
Insurance isn't a problem.
cheers
Rob.
Hello ,
After being in a 1998 model car ,it is not right to get into an older model than you drove before,
unless it is a true classic eg. wide bodied porsche,old triumph etc...There are only a few exceptions,
the GTR32 or 33 .
Both these hold there resale value better than gtst's etc.
I also looked at a 34GTT drove the thing and it did not compare to a gtr at all.
Why not join the Skyline club with a top gtr32, i like them alot,but could not buy one, because my nephew had one so i bought the 33gtr instead.
You really have to either love your nissans or your toyotas ...so choose your weopens...
I have already chose mine...
C u on the battle arena...
Regards
Tekin
i thought it sounded more like mike whitney from that dodgy Gladiators show that used to be on.
"Gladiators, choose your weapons!!!"
(wherein 2 6'5" guys steroided up to their eyeballs pic up soft padded sticks and begin a pseudo pillow fit... while wearing lycra and knee pads)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
