Rain is frustrating at first, then its the great fun... although i recommend you pay a wet track a little more respect then i did the 1st time. I spun off like 6 times that day (yeh so whats so unusual about that) and ended up driving home with tuffs of grass caught in my rear spoiler/windscreen wiper/rear views.
Spinning off the end of the main straight may be bad for your health.
Im sad to be missing this day, copping liquidated damages at work at the moment for runing over schedule so overtime it is.
  • Replies 76
Originally posted by benm
Just a question... if say you only get 10 people instead of the 40 wanted, im guessing everybody just gets longer track time or does the day end short ?
Well, we've currently got more than 10, but basically we are paying for the whole day, so we'll use the whole day regardless of how many people we have. Unless of course everyone gets sick of it and wants to go home :(
Originally posted by Luke C
I am coming to the track day on Saturday, but I haven't got my Skylines Australia membership yet even though I posted it about 4 weeks ago. Does this matter? I'm really looking forward to it now, rain or shine.
No probs. Just turn up on the day, and you'll be accepted, as long as there are spots left.
I believe we currently have 24 entrants. Not catastrophic, but still lower than desired (35-40).
Note that there is a late fee of $10 if you enter on the day.
Regards,
Richard
The weather was very kind ... the whole morning session was wet, with light sprinkling for most of the time. But that gave everyone a chance to play in the rain.
The whole of the afternoon was dry ... and the track dried up pretty quickly. Good since we were timing the afternoon.
Results can be seen here:
http://www.natsoft.com.au/cgi-bin/results....05/2003.WAKE.S1
A report from one of the entrants, with pics available here:
http://forums.clubrsx.com/showthread.php?s...&threadid=81618
Great day. Thanks to the organisers for putting it on. I actually left early at about 2.30 after running out of petrol. I figured I may as well get a headstart since I had to drive back to Newcastle.
I was pretty happy with a 1.17 on my first time at a track.
Top day. I'm so glad it dried up there after lunch.
It was good to have some propper timing on the day. Gives you something to aim for, and you can see your improvements. :D
My sincere thanks to the HCC for organising the day. I hope to attend the next one.
Cheers,
Scott.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
