hi i own a r33 gtst 4door series 1 i dont know how big the fule tank is i dont know how may liters per 100 km
and dont even know how much i should get out of a tank and my fule gauge is giving miss readings. the first half it says i ruffley get 180km the last hallf it says it onley gives me 90 km on the guage so that equals to 270hm per tank witch is really poor so what i did once was run it just keep driving i know thats bad for the car to run out with these kind of fule pumps but i ran it till it got to 330 on the clock it showed empty for 50km. and it seemed to have plenty of fule would start up easy. and im getting diffrent reading all the time on my fule guage each time i fill up my car. ive asked a machinc and he says all fule gauges dont show correct reading's but 50 km + is a big diffrence all fule gauges i see seem to read right.
i use boost 98 and i have aftermarket dashes but every thing else works fine the speedo revs boost temp oil so it cant be the aftter market dashes the car is pretty much stock apart from that
can any one help me on how to fix it if it can be please would greatley appreciate it
https://www.sau.com.au/forums/topic/123072-fuel-questions/
it could be your level sender. so a search.
its just a matter of opening up your fuel tank from the access in the boot and then mounting the level sender back on its mount. its a common problem with 33's.
but normally you'd get 300-350k's from a 33 with basic mods as they tend to run rich anyway.
https://www.sau.com.au/forums/topic/123072-fuel-questions/#findComment-2274025
This really hurts to see such bad fuel economy....
The 33 must be like a brick passing through the wind compared to the 32 as I know of so many 32's returning over 400km's to a tank of of juice (~50L)
Even the 3ltrs (mine, bl4ck32's and rbmans returns over 400km's per tank.
Unless you drive damn hard all the time it should not be returning under 400km's.
https://www.sau.com.au/forums/topic/123072-fuel-questions/#findComment-2275606
ok ill check it out but i dont know what side of the boot it is on or where it should be attached to or what needs to be attached to it now i know what it looks like all i have to do it find out where it is :laugh:
and see if it is on the bracket. and with the 32 it has a smaller engin as well 2.0 ltr compared to the 2.5 and turbo on top of it as well
Edited by R33sedanturbo
https://www.sau.com.au/forums/topic/123072-fuel-questions/#findComment-2276902
i get well over 400 ks out of my
33 usually around 450ks out of a tank has cat back exaust & pod filter i dont drive all that hard but give it a squirt every now and then . the only time it went thru more fuel was when the co2 censor was shagged run rich as hell at idle
Edited by mid life crisis
https://www.sau.com.au/forums/topic/123072-fuel-questions/#findComment-2289246
https://www.sau.com.au/forums/topic/123072-fuel-questions/#findComment-2289250
ive neva had the warning light come on b4 so thats a good sign after it was on empty for 50km so defently it is the fuel sender will have to do that then first time doing any thing to my car lol hope it goes well and i dont stuff it up
https://www.sau.com.au/forums/topic/123072-fuel-questions/#findComment-2292496
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
