hey all just having a bit of trouble sorting out the wiring of my hybrid ebc.
just one wire is stuffing me around. its an orange wire that it ment to be hooked up to either a "boost sensor, tps, map sensor" i cant get it to work properly. can anyon help on this subject? i searched the net and couldnt even find anything about installing them.
cheers guys, Alex
https://www.sau.com.au/forums/topic/123074-need-help-with-hybrid-ebc-install/
Dude, when we installed my one it was a complete pain in the ass!!! The instructions don't give you nearly enough detail and will confuse you more if you keep looking at it.
The wire needs to be tapped into the one from the ECU! It will not work on any other wire - trust me, we've tried it >_<
I think another one or two wires need the same treatment as well but not 100% sure now.
cheers guys, Alex
No no no.. Very easy to install...
Let me explain mate this is a 10min job :P
RED: IGNITION (+POSITIVE)
ORANGE: SENSOR (BOOST SENSOR/MAP SIGNAL)
GREEN: EARTH
PURPLE: (OPTION2;COMP)
GREY: (CONNECT TO EARTH FOR OPEN LOOP SETUP ONLY)
I’m assuming this is a R33? If so you only need to use 3 wires. Red, Orange & Green.
1: Connect RED (+IGN) to a positive once ign is on
2: Connect GREEN (-EARTH) to a negative or to body
3: Connect ORANGE (SENSOR/MAP) To your boost sensor. To a wire coloured WHITE with a small line of green thru it.
The stock boost sensor is located in the pic below. Just follow a small vacume line from the manifold down to where the master cylinder is, it’s just behind it (A SMALL BLACK BOX WITH A VACUME LINE STUCK IN IT) and you will find it has a plug connecting to it. It has 3 wires. Find the WHITE (with a small green line thru it) wire, it should be in the middle of the plug. Just pull it of and connect the ORANGE wire to it. You’re done!
Using this method gives you better boost response then using a throttle body signal from the ECU, I find it to laggy. And it was only made for cars without a boost sensor.
Happy Boosting.
Cheers,
Alex.
Edited by 217/r33
The wire needs to be tapped into the one from the ECU! It will not work on any other wire - trust me, we've tried it :P
I suggest you redo you boost controller setup because R34's have a factory boost sensor located in the same place :( Will give you much better response.
Cheers,
Alex.
I will take note of that one and re-jig the wiring... if you're right, you're a champion!
Also, make sure you do up the solenoid ports correctly, they are different for internal and external wastegates.
hey thanks for all the replys. i dont get online as much as i would like to so this is the first time i have been able to read my post.
i will go and try to wire that controller up right now. will post up the results. thanks again to everyone who gave their advice. cheers, Alex
Let me explain mate this is a 10min job :)
GREEN: EARTH
Happy Boosting.
Cheers,
Alex.
I had the first generation Hybrid EBC and that is exactly how mine was wired. ^^
Is it any different on the R34? The boost sensor on my car is located at the rear of the engine above it. I'm pretty sure we've tried the method you're talking about but it didn't work last time.
Another question, how much of an improvement are we talking about here?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
