hey
my car is a series 1 r33 gts25t. Lately my turbo has been making a very faint whining noise every every now and then. This happens between -30cmHg and -20cmHg (read out on blitz dual sbc spec s). This is the only time i hear this noise (under very light throttle), never when making positive boost or under hard/harder acceleration.
Is my turbo on the way out? Or is a maybe a slight leak somewhere, or possibly something else?
I've searched some other posts and people say they get a squeal/whine noise when making boost at say 3500rpm, yet i get a faint whine at about 1800rpm, so i'm not too sure...
https://www.sau.com.au/forums/topic/123089-is-my-stock-turbo-dying/
no, it doesn't blow any smoke (looked for that, and have also looked for any oil coming out of the turbo or piping and there is none).
the car has done about 104000km (assuming if it has been wound back, then more than this figure). It is a 93 model.
boost is stock and a setting at 10-11psi. But before the ebc (about 1 and 1/2 yrs ago) who knows what it could have spiked to during the period after the exhaust was fitted, as all i had to go by was the stock boost gauge.
mine does the same on slight acceleration - changed oil regularly and all seems fine tho - still makes slight whine (like a dog whistle almost) which I've heard on lots of others - bear in mind this turbo is spooling up to the phenomenal speeds it spins at just before the actuator opens so on slight accel your gonna hear something spin up - I haven't heard a totally silent one yet myself but I'm no expert either so every skyline I've driven or drove in might have been knackered lol!
the slight noise you could be hearing could be air passing through the bov. there is a point where you can hold the throttle where the bov will be open slightly. and since there is air permanently leaking around the bov through a recirculation hole, it can cause a whistle.
hey mad082 - you mention a bov (I'm assuming thats a blow off valve heh!) - do all r33gtst's have them or are they aftermarket addition?
I only ask as mine too makes this subtle whistle and it is at a certain point on the throttle as you said but I dont have an aftermarket dump valve on my car :D
theres other signs that your turbo is going anyhow - small puddles of oil in that metal piping that feeds up from your intercooler. There can be slight smears in the pipe that you can wipe of with your finger (charge pipe is it?) so dont fret if you pull it off and see that but if you pull if off and see it dripping then I'd be a bit more worried :D
smoke out the back on hard boost - basically oil escaping I think.
only know this as I had to disconnect mine getting to the spark plugs and we checked this area recently
all 33's came stock with a blow off valve... although the correct name is compressor bypass valve. it is situated just before the throttle body, on the cabin side of the piping. the are hooked back up to the intake between the air filter and the turbo, so that when you lift off the throttle the air goes back through the turbo to keep it spinning (like blowing on a kids windmill that you get from fair).
also i had oil dripping out of my intercooler piping at the throttle body, and a small amount through the piping before i did my frount mount. I thought it might've been the turbo on the way out, but after a few weeks with the front mount i pulled one of the new pipes off and there was no trace of oil at all. it turns out that the stock front seal on the turbo will always leak a tiny amount of oil. the front seal is like a piston ring. it isn't a full circle. it has a slight gap in it.
so my problem was just old oil, and a bit of blow by.
Edited by mad082
thanks guys. I will get the car on a hoist and a have a good look to check for tiny leaks in intercooler piping, as well as make sure the bolts on the tubo aren't loose.
Didn't think of the that tiny air recircualtion hole in stock bov, could be that.
Cheers...
Don't discount the bearings.
Mine had that whine on boost, it was on and off, and didn't really effect the performance.
I did a track day at Winton, all was good, but on the video, I coul hear it whining. high pitched noise.
A week later the bearings shat themselves.
So I got a high flow.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
