Hmmmm I took the car to the mechanic the other day to get my gearbox oil changed ...... and when I got it home I noticed what looks to be a rather nasty scratch in the passenger door :D:):D
I obviously cant prove he did it so I am asking is there any product that can help cover up my scratch?
The skyline is black and the scratch has come out white!!!! It looks really bad ... Its only about 1 and a half cm's long but its the principle of the matter .... I spend over a month finding my line with a body in really good condition and the very first time I take it somewhere they bash the door ... probably on the hoist...
I was thinking of getting a bit of paint mixed up to match and putting it on very carefully with a small brush...
Comments???? Ideas????
Please help....
MrGTST
https://www.sau.com.au/forums/topic/1231-scratches-in-paintwork/
I know exactly where you are coming from, I spent 3 months trying to find one with a near perfect spray job (only to realise later that the car was in-fact re-sprayed!!! - No matter, its a good job). Anyhow, same thing, one mechanic put a long scratch into my right guard, but luckily it was only a scratch in the clear coat and not the paint, So I just gave it a good cut using a cutting compound, and then waxed it. Came up good, I can only notice it now if I look closely. Take a close look at yours, it might not go through the paint, so this might be an option.
If it does go through, a paint shop should be able to match your paint, and put it in a can for you to spray over, but I recomend you don't take this road unless you have sprayed a few cars before and know exacly what you are doing. I've sprayed a few cars in my time, and still cant get these touch up jobs 100% as it is near impossible! I've done a few where it appeared to look OK, but in certain angles of sunlight, the respray was visible...
If it is as small as you say, then a touch up texta, or a very fine brush will be your best bet, as you will cover the smallest amout of surface area with new paint, hence the chance of it being noticed is minimised.
Where abouts are you located? If you are in melbourne, I can recoment a paint shop that does a good job when it comes to matching the color of your car...
Zahos
Hmmmm thanks for that advice... I think that it has gone through the paint :D .... I will go get some paint mixed ( I am in Perth ) and be very carefull and see how we go ... luckily there a couple of out of the way spots that I can test first so I can see how it is going to go...
Mr GTST
MrGTST
A good panel shop can either buff the scratch out depending on severity or do a good job of touching it up then buffing it so u cant notice it.
I have 2 small scratches on my passenger dor which were there when i bought my car, I have someone lined up to remove them.
Hmmmm thanks for your opinions ..... I have gone and got some touch up paint .... I will give it a go tonight and see how it looks ( I will test it on some more discreet spots first though. )
I hope it comes out alright .... I was very proud of the cars conditions prior to this happening.
MrGTST
just remember to clean the brush well with thinners or turps after testing it, otherwise it will harden and make it difficult to do a good job on the door!
Also use a generous amount of paint on the brush, but only let it **VERY LIGHTLY** brush up against the panel...
If you get this technique right, you wont get the brush look, and it will come out looking much smoother and less noticeable.
Clean the area of application VERY WELL, and air dry it with a compressor or a hair dryer before application. After the paint has dried for about 24 hours, give it a good buff, so it may blend in a little more. (This rarely makes a difference, but possibly can).
Cant think of any more hints....
Zahos
Hiya Again.....
Well let us just say that the touch up paint didnt work.... It came out pretty bad so I very carefully scratched it off....
So I am back where I started .... I need a professional job.
I will take it to my local Panel Beater ( I have used him once for my last car ) to get a quote but Adam 32 I am interested in finding out more from your friend???
I am a perfectionist and want to make sure a good job is done ( nothing is too good for my baby :uh-huh: ) and dont want to just randomly pick something out of the yellow pages :(
Therefore as I said Adam 32 can ya help me out!!!! :D
Thanks
MrGTST
mr gtst
take it down to the local panel beaters or wherever you were going to take it
ask them if they would either repsray the entire panel (if the scratch is bad) or whther they could buff it out with the electric buffer
if they saf theyd just buff it out then let me know and we can do it on the weekend
if they say respray then the scratch is probably too deep to buff out and will need to be painted. if this is the case my mate will still do it for you but will cost almost the same as anywhere else as they have to mix-up the minimum amount of paint of that particular paintcode do no matter how little paint you need the minimum is like 2L or something so theywill charge you for it.
either way let me know and good luck!!
Hmmmm I went to the panel shop ....
The guy looked at it and said it would need to be resprayed....
The quote ..... $400 ....
The want to basically rub the whole door back and respray the whole thing.
Hmmm $400 is a bit excessive for about a 1cm scratch.
Maybe I will just have to live with it :(
Out of curiosity what would happen if you tried to buff it out but the scratch is too deep???? Would it make it look better/worse???
Is it worth trying.
MrGTST
Hmmm but I havent really done much apart from try touch up paint, which didnt look good at all...
The only other thing I have done is tried polish but that was just with an old t-shirt :(
I am hoping a proper buffing job could make it look better.... obviously it wont be perfect but if I could just get it to be less noticeable that would be good.
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
