My car for some reasons has stalling problems after hitting boost when its warmed up.
It has stalled, then when I turned it back on stalls again, then on second time it starts but at times when I gave it some gas it splutters and then plays.
THis only happens when I rev it past 2000 RPM, I drove below 2000 rpm yesterday and didnt play up at all.
What could this problem be??
https://www.sau.com.au/forums/topic/123104-problems-after-boosting/
how old are your plugs? what type and gap are they? does it only stall when you are decelerating? if so, there is a good chance its your plugs. mine would stall after giving it a bit of stick then slowed down. put new plugs in and went away.
very much doubt it is the bov. seen plenty of skylines with atmo bovs that run fine. most common problem with atmo bovs is people put them on then don't tension up the spring so they leak. and when they do run rich on gear changes it is only for a split second. they don't constantly run rich.
stock car...
spark plugs have been changed ot new iridium NGK... coil packs r fine too. AFM is clean.
no idea...
i think it may something to do with the fuel system (fuel lines, fuel pump)... thought maybe u guys could chime in with something else...
getting same prob myself at times - seems ok and revs are stable (but higher than normal - idling at 1100rpm ish) but after accelerating and using boost - come to slow down and it can stall here n there.
only thing I can think of personally for mine is AFM on way out as other owners I know had similar trouble >_<
well could be who knows... afm eletrics might be f**ked up.
could also be idle control valve. we did some 'tuning' on my car and the next day idle was all over the shop. first it would idle high, then it would stall, then it would hunt. ended up taking the idle control valve off and giving it a good clean. sorted it out for me.
I put money on faulty AFM.
A mates car did the same thing. Started then stalled after one or two seconds. I unplugged his AFM, then started it with a bit of throttle in there, and he limped it home. It would cut out over 2000rpm (exactly), but it made it. New AFM and it runs perfectly.
idle control valve is at the back of the motor on the drivers side. it sits at the end of the plenum at the top. it has 2 pipes coming out of it, 1 of them underneath it. it has 2 plugs on it. if you look at it from the drivers side you will see the idle srew (about 8mm in diameter and takes a flat blade screw driver... i think) it is 3 screws to get off, the 2 plugs and 2 hoses. the bottom hose is a bit of a pain to get on and off.
to clean it you need carby cleaner, and optional is some pipe cleaner. just give it a good spraying. i took the little motor bit off so i could clean it completely. then when you put it back on you may have to adjust your idle, unless you get your screw back in the same spot.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
