Hey Guys,
Just a question for anyone with an R33 GTR. Where did you guys get your Oxygen sensors from if you have replaced them, and how much did you pay for them??
I cant see the value in buying them from nissan for a total of $450. I just want some universal ones that i will adapt my old plugs to, but havent had any luck finding some over the last 2 weeks!
The specs are: 18mm thread, Titania Sensor, Three Wire, voltage range of 0 to 1 volts.
As you can see from the pic, my car is a 32 GTR, but i am running 33 dumps, which have the larger thread. So alternatively, if anyone knows where to get the bungs from to run the smaller 12mm thread 02 sensors from that would be great. (or even if you know of where to get them fabricated in Brisbane).
Thanks Guys, im beginning to get desperate!! :D
SLVR32GTR
Edited by SLVR32GTR
https://www.sau.com.au/forums/topic/123107-gtr-02-sensor-cheap-alternative/
hey man, im in the same boat.
i asked this question a little while ago, but didnt get any answeres!
hopefully someone can help us!
steve
I know what you mean, i have been asking all of the reputable performance shops around Brisbane, also NGK and what not, and all i have recieved back is, "ahh sorry we dont have them or even know where to get them!"
Gets a tad annoying considering i need them in order to do my long awaited turbo conversion!
Surely someone on here has a 33 GTR and has changed there 02 sensors!
G'day blokes,
Changed my GTR 33 sensors 2 months ago. Cost me $339 for the pair from Nissan(genuine at trade price). I went through the long drawn out process of looking, phoning and eventually talking to technical specialists at most aftrmarket places for replacements. No luck, not made for direct fittment.
G'day blokes,
Hehe,
I thought that this would be the response. I suppose i am just suprised that nissan succeeded in making absolutely every part for a GTR the hardest and most expensive parts to come by! :D hehe
Ohh well, i suppose $339 isnt toooo bad.
Thanks mate.
Oh and for the record, i even went as far as contacting specialised dealers in NZ and the UK with still no luck!! Unbelievable.
If the GTR uses normal Zirconia type Oxygen Sensors (like the RB20/25), which im sure they would, then just buy a universal sensor with 18x1.5mm thread (standard O2 sensor thread) and you cut the connector and wire from the old sensor and crimp it onto the new universal sensor. (it will come with the crimp terminals and everything)
Universal sensors are around $40 - $80 at most.
You can't solder Oxygen sensor wiring as its stainless. (Thats why they supply crimp connectors with the sensor)
Thats the problem though. GTR's (32 and 33 anyway) use titania sensors that are very hard to come accross. Basically 32 O2 sensors (12mm thread) can be bought through NGK, and nissan, but 33 (18mm thread) i have only found through nissan so far.
Talking to Sydneykid, he mentioned that a generic bosch lambda sensor should work for this application and only cost around $80. I have not researched this yet to verify though, so dont take it as gospel. These sensors are available through places like Repco.
Tony
VL Commodore and R31 use Titania 02 sensors that have the smaller thread size, have you looked into them at all?
Titaniam sensors are smaller due to their design. They are actually not a self generating sensor like the zirconum type, but a voltage reference sensor.
What this means is that instead of self generating a 0-1V output, it uses a resistor that changes resistance with the air/fuel ratio to give a 0-1V output. It uses the power from the heater 12v supply.
You can interchange them as them as they both give a 0-1V output. The only thing to note is that all Zirconia type sensors are the larger 18mm thread and Titania types are typically the smaller thread.
I have in the past, removed the bung from the exhaust manifold/dump pipe with the smaller thread for titania sensor and got a bung from like R33 dumps that have the 18mm bung and used the cheaper Zirconia type sensors on RB30 engines that originally used the Titania type sensor.
Do the GTR dumps have a large 24mm bung that is screwed into the dumps with the O2 sensor hole inside the bung? If so the bungs just unscrew.
  • 1 month later...
  • 1 year later...
Site sponsor Kudos does them HERE, but for a 32 GTR its still ~$325. FWIW R31/VL sensors are <$100.... I also need some, and i'll put them in when i install turbos and xforce dumps (which also come with reducers).
Does anyone know if all titania o2 sensors are electrically the same WRT sensor output? (and therefore theoretically adapable?)
Guest
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
