  • Replies 40
haha i have been slowly accumulating!
so far i have (on the cheap!!!)
stock r33 rims two have different tyres and two have no tyres
some old 16 inch tyres to put on the rims with no tyres that i bought for $20 (both)
now im just looking for some matching tyres for the other two wheels, but if not i guess they will have to do, they are going to get destroyed anyway ;)
i dont want to kill my new expensive front tyres on my 17s so ill run the shit tyres on 16s all round i hope i can keep the car on the skidpan :)
what are u going to use on the skidpan?
Edited by siksII
put some good tyres on the front, otherwise your car will understeer like anything. The back ones will heat up and get grippy, and the front wheels will just get pushed and lose grip.
your front tyres don't get worn much because they should be pointing in the direction you're sliding :)
your front tyres don't get worn much because they should be pointing in the direction you're sliding :P
hey mate thanks for the info, i have been to the skidpan before so i know what your saying :)
i have found u still end up eating up the edges of the front tyres, and i would like to have the extra front grip as you say but i dont want to ruin the edges of my new front tyres
Guest Mashrock
$600 a set (4)
see photos.
i think i will head out again this week and get a set of dunlops aswell. as hes saving a set for me.
tyres shown are yokohama ao48's
the photo of the single tyre is probably the most worn that i have.
i.e. they are pretty damn new.
i can grab more if anyone likes.
sizes are 255/40/17, and i beleive some 235or225/40/17
  • 1 month later...
  • 4 months later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
