280rwkw, Stock Turbos Stock Boost
280rwkw on stock turbos?
i dont think so tim :blink:
The car was dynoed at willall racing by Martin Donnan and Peter Hall reasonably respected tuner and engine
builder respectively. I will post the graph tommorow. The turbos are stock, please feel free to check with Steve Cramp, Manta Racing, also a respected racing driver, engine and gearbox mechanic of some repute and dabbles in a spot of suspension work. In fact after checking it was 283 rwkw on standard boost.
P.S
1. My name is Warren
2. Your Avatar suits you
Edited by R31Nismoid
  • Replies 57
willall/martin donnon is know here in S.a for giving out higher than normal dyno readings!
yeh this dyno that dyno. f**k is there a normal dyno reading other than yours
r31nismoid is a toss he knows all!!!!
I bet you know more huh?
All i was saying is 280rwkw from a STOCK turbo'd GTR on STOCK boost is nothing but totally unreasonable
Please tell the crowd how that is wrong, and where your knowledge says thats possible
cheers
This was achived with stock turbs, 3in straightthru exhaust, Pods. PowerFC + boost controller set on stock boost. Thats it.
Anyway, back on topic. To the OP, you should be fine without one untill you do other mods.
What is the difference between the blue line and the green line? What does the blue line represent? Is that your car 100% stock or something?
cheers
mechanic for 25 years 15 of them with gibson motorsport and so yeh i might know more ya toss
I have posted up a 4wd drive comparison, this was prior to the PFC, boost controller, front pipes and exhaust. I agree with dyno results being all over the place but what can u do about it you have to trust someone or something, I am at the point where as long as it keeps going up who cares. I might add I change the oil every 2500km and immediately after a track day and I only use AMSOIL turbo formulated synthetic with an oil cooler. Vven with this the oil temp sometimes hits the end stop. When I do the fuel pump regulator and injectors I will post the results after another dyno run.
BTW I still havent had a response to my initial qusetion surely it cant be that hard a question.
so what did you gibson guys make with the stock turbos (on the factory boost leve)?
Oh... thats right... you were using steel wheeled turbos and not the ceramic ones
my bad
my bad
who gives a f**k about boost level rwk is all that matters. nobody races dynos
ceramic turbos on 20+psi you dont think so well i know so been there done that 15 years ago toss boy
Edited by brenr33
Considering the only comment Nismoid made was in regards to the fact that 280wkw on stock turbos and stock boost is an unreasonable figure, I think boost level is quite relevant. Or is it just that in your 15 years in motorsport you never learnt to read?
And isn't the statement "rwk is all that matters, nobody races dynos" a bit of a contradiction, since every dyno reads differently. I would have thought it was rwk(w?) that meant nothing, and that it was all about Lap Times and ETs? Or am I missing sometihng somewhere that says if you run a 11s pass with 400rwkw you're obviously faster than the guy who ran a 10s pass with 380rwkw?
Edited by Hakai
SK, I have just ordered a nismo fuel pump and regulator "as pictured" along with a set of nismo 600cc injectors to strengten my fuel system and be in a position to upgrade to r34n1 turbos or other low mounts GTSS maybe for track and targa.. I have a standard R33 GTR except for apexi powerfc and boost controller which made 283rwkw post an exhaust change. My question is after fitting the regulator do you maintain the standard pressure as it now "guaranteed" or should you increase it and if so to what pressure.
I also call BS on 283rwkw with stock turbos. I've seen 250 odd a number of times. Doesn't really matter anyway unless you are trying to tell us that it's for real. It's only useful to you if you keep using the same dyno and operator as a comparative thing. I personally try to avoid dyno's that are known to give inflated figures because I would rather know the truth - or as close as is possible given the known drawbacks of dynos generally.
That said, with 600cc injectors and the turbos you are thinking of you will be fine to keep the stock fuel pressure.
seems like that dyno needs a tuneup!
It was done on shootout mode. Should be fairly acurate. My guess is that the blue line is stock boost, and the green line is considerably higher than stock boost. Was probably tuned on high-boost because if the temptation was there to raise the boost, then you wouldn't need a retune.
 Share
    • It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
    • lol I didn’t even notice the bird
    • I like the 'Beatles album cover, but with bird' element of this photo as well, haha
    • Hi Gents, Someone I know (experienced engine builder) built an engine. It had some chinesium rods that came with ARP 2000 bolts. One failed on the dyno, destroyed the whole thing. The only possibilities are: Installation error. Possible, but we should discount it almost 100% because he knows what he's doing. He doesn't discount it that much, because he's being hard on himself. QC/QA problems with ARP products. I'd like to discount this, but I have heard a number of stories about similar failures, and stories of some builders buying 2 sets of everything, x-raying everything, and picking only those bolts that they are completely happy with. This behaviour coming from anecdotal stories of ~1% failure rates. 1% of all rod bolts failing would be about 1000x higher than I would expect to be anywhere near tolerable. If I were ARP I certainly wouldn't even be selling the product if they were dying at that rate (for non-installation error reasons). So, I would prefer to discount that possibility too. Fakes. Specifically, fakes being sold bundled with cheap rods sets from CCP factory B in Shenzen, or wherever the stuff is being made this week. So the question here is, does anyone else have some horror stories that would point to fakes being circulated in this manner?
    • I forget this is an au website, my GTR FS5R30A was 2200 AUD delivered but I did have to go to a warehouse near the port to pick it up myself.
