280rwkw, Stock Turbos Stock Boost
280rwkw on stock turbos?
i dont think so tim :blink:
The car was dynoed at willall racing by Martin Donnan and Peter Hall reasonably respected tuner and engine
builder respectively. I will post the graph tommorow. The turbos are stock, please feel free to check with Steve Cramp, Manta Racing, also a respected racing driver, engine and gearbox mechanic of some repute and dabbles in a spot of suspension work. In fact after checking it was 283 rwkw on standard boost.
P.S
1. My name is Warren
2. Your Avatar suits you
Edited by R31Nismoid
  • Replies 57
willall/martin donnon is know here in S.a for giving out higher than normal dyno readings!
yeh this dyno that dyno. f**k is there a normal dyno reading other than yours
r31nismoid is a toss he knows all!!!!
I bet you know more huh?
All i was saying is 280rwkw from a STOCK turbo'd GTR on STOCK boost is nothing but totally unreasonable
Please tell the crowd how that is wrong, and where your knowledge says thats possible
cheers
This was achived with stock turbs, 3in straightthru exhaust, Pods. PowerFC + boost controller set on stock boost. Thats it.
Anyway, back on topic. To the OP, you should be fine without one untill you do other mods.
What is the difference between the blue line and the green line? What does the blue line represent? Is that your car 100% stock or something?
cheers
mechanic for 25 years 15 of them with gibson motorsport and so yeh i might know more ya toss
I have posted up a 4wd drive comparison, this was prior to the PFC, boost controller, front pipes and exhaust. I agree with dyno results being all over the place but what can u do about it you have to trust someone or something, I am at the point where as long as it keeps going up who cares. I might add I change the oil every 2500km and immediately after a track day and I only use AMSOIL turbo formulated synthetic with an oil cooler. Vven with this the oil temp sometimes hits the end stop. When I do the fuel pump regulator and injectors I will post the results after another dyno run.
BTW I still havent had a response to my initial qusetion surely it cant be that hard a question.
so what did you gibson guys make with the stock turbos (on the factory boost leve)?
Oh... thats right... you were using steel wheeled turbos and not the ceramic ones
my bad
my bad
who gives a f**k about boost level rwk is all that matters. nobody races dynos
ceramic turbos on 20+psi you dont think so well i know so been there done that 15 years ago toss boy
Edited by brenr33
Considering the only comment Nismoid made was in regards to the fact that 280wkw on stock turbos and stock boost is an unreasonable figure, I think boost level is quite relevant. Or is it just that in your 15 years in motorsport you never learnt to read?
And isn't the statement "rwk is all that matters, nobody races dynos" a bit of a contradiction, since every dyno reads differently. I would have thought it was rwk(w?) that meant nothing, and that it was all about Lap Times and ETs? Or am I missing sometihng somewhere that says if you run a 11s pass with 400rwkw you're obviously faster than the guy who ran a 10s pass with 380rwkw?
Edited by Hakai
SK, I have just ordered a nismo fuel pump and regulator "as pictured" along with a set of nismo 600cc injectors to strengten my fuel system and be in a position to upgrade to r34n1 turbos or other low mounts GTSS maybe for track and targa.. I have a standard R33 GTR except for apexi powerfc and boost controller which made 283rwkw post an exhaust change. My question is after fitting the regulator do you maintain the standard pressure as it now "guaranteed" or should you increase it and if so to what pressure.
I also call BS on 283rwkw with stock turbos. I've seen 250 odd a number of times. Doesn't really matter anyway unless you are trying to tell us that it's for real. It's only useful to you if you keep using the same dyno and operator as a comparative thing. I personally try to avoid dyno's that are known to give inflated figures because I would rather know the truth - or as close as is possible given the known drawbacks of dynos generally.
That said, with 600cc injectors and the turbos you are thinking of you will be fine to keep the stock fuel pressure.
seems like that dyno needs a tuneup!
It was done on shootout mode. Should be fairly acurate. My guess is that the blue line is stock boost, and the green line is considerably higher than stock boost. Was probably tuned on high-boost because if the temptation was there to raise the boost, then you wouldn't need a retune.
 Share
    • Hi and welcome. What are you planning to do to the car or will you keep it stock?
    • https://windowmotor.com.au/collections/02-07-v35-nissan-skyline?srsltid=AfmBOorAnTNYaD1tXzczAKZFqnDkZy23WgPXNfVscyeRKHhVNkiaC-WH https://www.gumtree.com.au/s-v35+stereo/k0
    • Heaps of historical info on this, a quick Google gave dates back to 2012, all talk about identification markings, dimples, shapes of mounting surfaces, washers, that are concave or something to match the fasteners mounting surface, which ARP states that if the washer, if it uses a washer in its application, isn't the right way around, it can cause premature failure,  even if it was torqued up correctly with whatever lube is meant to be used There is even talk about getting the bolts Xrayed to check the structure, one was about some builder getting multiple sets of bolts, having them Xrayed, and picking from those results Nowadays identical "looking" fake parts, in identical looking fake packaging are everywhere, with all the markings and stuff, the only way you know they are not legit is Xray or when they fail I assume if you don't want fake parts, and don't have a Xray machine handy, is to get them directly from ARP in the USofA, aftermarket rod and head bolts aren't something to take for granted  Imagine building a big dollar build only to find you lunch it because of an inferior fake fixture let go 😫
    • Quick update team on the build Things done. Installed Diff Brace ( TMR Performance ) Removed Steering Rack and replaced bushings with GK Tech bushings Remove Manifold and replaced Rocker Cover Gaskets and the Spark Seal Tubes Installed 1000CC Bosch Fuel Injectors Installed R35 Spark Plugs ( Pre-gapped to 0.28"  Installed Z1 Coilpacks Removed Fuel Sender unit and modified OEM pump to fit the 350lph Fuel Pump Installed Fuel Sender unit back with a Fuel Return system ( TMR Performance Fuel Return V2 )  Setup Fuel Lines that were AN lines and used P-Clamps to secure them to body ( This is needed to make this road legal in NZ ) Setup Fuel regulator Setup Vacuum lines from Wastegate to boost controller ( 3 port mac valve ) Wired boost solenoid to the EVAP sensor ( Behind manifold of car ) - Polarity of cables doesn't matter Setup BOV and Fuel Regulator lines Installed both aftermarket Aero Fenders ( Sourced from Japan ) Received Impul 280km/h Speedo ( Sourced from Japan ) Installed Carbon shift console Drive down the road untuned without creating boost pressure to test for leaks ( Video attached ) Setup JRP Racing 14in1 Gauge with Boost pressure being monitored Buttoned car back up and Tow to tuning shop in the mighty DE ( Nissan Elgrand E51 ) - VQ35DE Tuning platform is EcuTek and am hoping to 550WHP ( Dyno day is 9th and 10th of October )  Had Shop weld in a new Exhaust piece to connect Downpipe > Motordyne Resonator and to add x2 02 Sensor bungs for an AFR Gauge that will hook into the JRP Multi-Gauge    20240927_181518.mp4 20240927_181618.mp4 20240928_192844.mp4
    • It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
