Hey all,
Just curious as to what is needed to obtain a log book from CAMS. I ask this because I would like to have my car log booked for two reasons:
1. To clock up enough hours and have my log book stamped so that I can apply for a C3 licence at some stage in order to import a race only car
and
2. To get race rego on the car.
Now, this second point I'm not 100% clear on, but have been told that once a car has clocked up a certain number of 'track hours' that the car can be transferred to a 'race' registration enabling it to be driven to and from the track/workshop, and for testing purposes without having to apply to CAMS for a permit each time.
Have I got this right, or am I way off...
Thanks
Dane
https://www.sau.com.au/forums/topic/123150-log-booksrace-registration/
re #2, you cannot get rego on a car imported as a "race" car. No matter how many races it has done.
You can get rego on a car imported as a "rally" car which is identical process through DOTARS except that you need a NR CAMS license instead of NC. Once you have NR you can get NC by doing an online lecture and paying the upgrade fee about $150. All the details for getting NC and NR are on the cams website, but basically once you have PC (formerly C3) you need to do 6 races in a 12 month period and be observered at those events.
In NSW once you have either a complied or a rally import car, you can apply for rally rego. You need a L2S or higher license only for rego, a log booked car with either full compliance or rally import approval, a safety inspection by a CAMS approved rally scruitineer and a heap of patience when you get to the RTA :)
In NSW if you have rally rego you can:
Drive and in to CAMS events
Drive to and from Practice
Drive to and from Workshops.
As long as you obtain a permit every day you want to use the car.
My GTR race car has rally rego and it is brilliant, saves trailering the car everywhere, didn't have to pay for SEVS compliance and I can use it for everything I ever need to :spank:
i am going down this path also
called cams h.q. and then got put through to cams nsw
first step before anything re log book - roll cage!!!
cams bloke basically said dont call back until you have cage installed in your car
yeehaww
Hey Mark I was checking out roll cage rules with CAMS the other day too.
ANyone can make an approved cage as long as they follow:
One of the homologated designs from the CAMS book (I am using 253-17) basic 6 point cage with diagonal between top of middle hoop and bottom of side hoop.
CDS, CDW or CEW grade mild steel
Main hoop 44.45 diameter (2.5mm wall) or 50mm (2.0mm wall)
All other components 38mm diameter (2.5mm wall) or 40mm (2.0mm wall)
cold bent tubing
"highest possible quality welding with full penetration".
Once the cage is done CAMS send out the cage declaration form for the builder to sign, then it gets a ROPS registration number.
cold bent tubing
duncan any chance you can get me a copy/scan of that part of the book? or is is in that pdf on the cams website?
In NSW once you have either a complied or a rally import car, you can apply for rally rego. You need a L2S or higher license only for rego, a log booked car with either full compliance or rally import approval, a safety inspection by a CAMS approved rally scruitineer and a heap of patience when you get to the RTA :dry:
My GTR race car has rally rego and it is brilliant, saves trailering the car everywhere, didn't have to pay for SEVS compliance and I can use it for everything I ever need to :D
Thanks for that Duncan :banana:
My car has full road rego at the moment, so transferring to rally reg shouldn't be an issue.
What is involved in obtaining a permit each time? Is it a pain, or is it an easy ph. call etc? Is there a limit to how many permits you obtain? I'd be looking at probably on average 6 days a month.
Mark...yes and no >_< got a fax number?
phunkey, in NSW it is a call to an automated service. I'm not aware of any limit at one stage I was getting 5-6 a week and never got questioned!
You need to make suer all the rules in Vic are the same they are probably similar. Call the CAMS Vic office and ask about rally rego.
Pretty sure that for Victorian RP cars you don't need to call up each time, as the Rally Permit is itself a 12-month UVP. You will need a R3 license or above, and not L2S+ like NSW..
With RP plates you can use the car:
- During CAMS-approved rallies, including SS and transport stages
- Travelling to and from a rally, and its scrutineering
- To and from Workshops
In addition to this, you can also use the car in testing for an approved rally, but you must apply to CAMS for a letter which states that testing is permitted.
But yep, the process for applying for a Vic rally permit this will be the same as NSW.. in that u will need a cage with ROPS registration number, as well as the car logbooked and scrutineered by a CAMS official before it can be registered.
Edited by r171
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
