Hey ladz,
i have just bought a Greddy PROFEC B 2 Electronic Boost Controller, and im now gonna ditch my good old Turbosmart Bleed Valve type Boost Controller...
seen as though my Turbosmart one is already installed, does that mean i can just replace that Turbosmart gate with the Profec 2 Soleniod and use all the existing connections?
if so this means i can simply take out the Turbosmart one and just put the Profec Soleniod in its place and use all the existing tubing....
correct or incorrect?
any advice much appreciated..
Beef
https://www.sau.com.au/forums/topic/123174-new-boost-controller-help/
Sounds right.. I just got one of these as well for the s15. There are three ports NO, NC, COM. COM goes to the actuator. Boost source goes to NO assuming you're running an internal gate. Make sure all the plastics caps are taken off the solenoid too if you got it new. I ran some new vacuum lines because before my mbc wasn't mounted, but the solenoid needs to be mounted to the body of the car and my existing lines are too short.
Download the english manual from www.greddy.com. I read it a few times and it helps with tuning it.
Edited by ansch
Make sure your boost source is coming from a cooler pipe or compressor housing, not from intake plenum. solenoids dont like vacuum.
quote name='BHDave' date='22 Jun 2006, 02:54 PM' post='2276971']
No.
The bleed will be tee'd to bleed boost off. The ebc has to be inline and will likely have the in and out marked on the case of the solenoid. In is the boost source, out goes to the actuator/wastegate
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
