I use Wheels World. I figure someone that aligns ferrari's and race cars on a regular basis is good enough for my GTR :laugh: also has a wealth of knowledge and will happily set the car up to suit your particular driving style.
You mean a curb?
I think they were about $35-$45 last time I had one done.
Someone told me once that wheel alignments are really cheap in the Eastern States, like $7 or something stupid.
Actually, I think he means a kerb.
If you are going somewhere other than a specialist like Wilkinson's it pays to know what alignment specs you want in the car. Chances are the nearest Bob Janes will have absolutely NFI.
The other thing is to ask when the shops alignment machine was last calibrated. Sometimes this never gets done, so your $60 will be mostly wasted.
by any chance does wilkinsons or WA suspensions sell tyres aswell as do wheel alingments/suspension work? I really need a new set and not sure where i wanna buy them from, cause i wanna get a wheel alingment done after the new tyres are on...
so i assume if wilkison is a sponser you can trust them with your car?
i sereiously need to get my alignment sorted. i might give them a call
steve
as i mention above... i went to wilkison and they did an awsome job, i forgot to mention on sauwa member so ni discount ahah :laugh:
i went in told them what i use the car off and they setup the alignment from that
and what can i say it was a great job took it to the track that night and it work perfect :O
what did wilkison charge and did they do it while you wait?
i went in there about lunch on a friday afternoon asking for
wheel alignment (drift setup)
install tie rods (which i supplyed)
and supply and install pine-apples
they were very busy... but because i needed the car that night (for the drift practise) they fit everything in and i had the car ready at like 4pm...
all up cost me close to $200 without sauwa discount
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
