Hey all, been meaning to ask for a while but kept forgetting.
I have a fair idea of cams but not entirely the effect of them according to their lift / degree's.
Ok, so my understanding is that cams have lift, and I assume that this relates to how high the cam goes when rotating. However, I dont know what the degree's mean or how any of this gives different power gains at different RPM... Engine internals are certainly not my strong point.
Thanks
C
https://www.sau.com.au/forums/topic/123200-cams/
depends on the setup.
usually more lift = more flow, but you also need duration. the problem lies in getting a good combo as at high rpm you can get valve slap, eg over revving. to compensate you can use tougher valve springs etc. but it depends on the lift. if the lift is more than the springs can take the springs will bind, or over compress.. VERY bad.
if you need high revs eg nat asperated, you need less duration more lift... to raise the rev range
use as a guide as this may not be correct to some out there ;)
Edited by bogcock
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275388
So for an internally-stock GTR, you wouldn't want much lift, is that right? I think the tomei poncams are 262 and 10.2 and are supposed to be good for stock engines with bolt ons.
Thanks for this info too.
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275394
poncams are good because they use the stock valvetrain.
if you want big power you will need more lift and around 264 duration..
procams are better, but you need to change valve springs, retainers etc
for a stock gtr (internally) cams wont really give too much benifit. ive seen stock cammed gtrs running 600hp with no problems. attend to other parts 1st, such as turbos, ecu, injectors zorst etc
Edited by bogcock
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275428
Christian - i went for std turbos, tomei poncams 260 9.15mm.
It made a huge difference to the midrange and drivability.
Someone else on here also did poncams on std turbos...
Full list is:
1.1 bar
turbo back exh
stock airbox, high flow filter
poncams + adj wheels
i reckon area under the curve is pretty good, and low down power...
sure turbos would have made more power, but drivability is very much improved... and I don't drive b/w 5000 - 8000 rpm all the time - 85% if the time is between 2000 and 4000 rpm
don't completely discount cams ;)
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275514
Yeah between my 2 GTRs I have done mods quite differently but gotten similar power, but the power is very different.
Old GTR;
Power FC
Full Exhaust
More Boost
243rwkw
New GTR;
Cam Gears
FPR
Full Exhaust
More Boost
250rwkw
But the way that power is produced on the new GTR is astounding compared to the old one and I reckon its all cam gears.
Poncams are only $850-ish delivered from Nengun, not sure how much fitting is tho.
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275909
Bit OT - but whats the diff between a PonCam and a ProCam ?
Hi B-Man
I have just been doing similar research on cams also, and have found that while all the specs seem similar on the poncams and low end procams (eg 9.15 lift, similar durations), the procams are apparently a more aggressive "ramp" affecting the speed of valve opening. This means that the procams need the uprated springs where the poncams dont, and presumably affects the power/torque delivery.
The Tomei website has some good info in Engrish describing the cams.
Cheers
Ned
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275926
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
