Top of the range Tein HA's
Retail $2500 willing to part for $1600 ***** $1400 THIS IS AS LOW AS I CAN GO*****
The coilovers are from a show car around 50km use to shows. willing to deliver anywhere in australia and a full warranty is still honoured through Car Toys in adelaide.
Why settle for second hand coilovers with a dodgy background or cheap imitations? These are Tein's arguably the best Japan makes. Monotube design [not cheap twin tube] fully rebuildable. Perfect for the trach or serious street use.
I have already dropped the price by nearly a grand.
PM me
Edited by 34rs
https://www.sau.com.au/forums/topic/123215-tein-coilovers-lowest-price-r34gtt/
  • 4 weeks later...
PM me
are the coilovers stilll for sale?
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
