OK guys, I have recently became the proud owner of a 1990 GTR with a relatively stock engine setup. It currently has an R33 RB26 in it with a chipped stock computer. It has a Trust FMIC, HKS hard pipes, Apexi air filters, 3inch HKS cat back exhaust, HKS twin plate clutch, and a Koyo radiator with electric fans.
Now I have been looking around online to see what guys are running for power and mods but I am not sure what I should be aiming for. My car will be street legal(one of the last cars to escape Motorex before they shut the doors) in Arizona. This car will not be my daily driver, more the weekend warrior/have fun at the track and woop up on vettes and such :-) I am interested in being able to drive it on the streets so I will not be gutting it and making it full race. I will be doing autocross and occasional drag racing. Not really interested in wheel to wheel but would like to hit some other track events. I will also be keeping the AC in since I am going to be in AZ(summers are killers here).
From what I have been reading 550-650whp(~400-480Kw) sounds like the sweet spot for an R32 GTR. I want to build a good powerful and reliable engine. I know the RB26s when built properly can run this kind of of power day in and out. Now I do not have unlimited resources to spend on my car so I kind of want to do it right the first time around, and heed the advice of others who aready went down the bumpy road.
BOVs, I am currently using the stock BOVs that recirculate the air. I like this setup, but I wonder when I crank the boost if it will be enough. Do guys ever add in a 3rd one? 2 stock ones recirculate and one vents to atmosphere. Or should I get a couple of greddy BOVs with the hose adaptors to recirculate? Just some thoughts going through my head.
Spark, ok at what point do I need to worry about getting more/stronger spark than stock? I have seen the splitfire coil packs along with other spark boosting modules. Is it a matter of how much boost I am running?
Too much power...yes there is such a thing even for GTRs. I have read at certain power levels things start to break on the GTRs. I've heard the trannies, especially 3rd gear go boom with too much power. I've also read/seen that the front diffs break and shear off the oil pan. OK, I know when your messing with big power and racing that things are going to break from time to time, but I would like to keep it to a minimum. Anyone know what this point of power equals loads of destruction is? Basically how much power can I run and not have to worry too much about other things breaking on me?
I have a pair of low mileage R34 N1 turbos (707160-4 I think they are the same as 707160-5). The int is A/R 60 M24 and the ex is .64. I originally bought them thinking they would work for me but it seems like everyone going this route is using HKS 2530s. Not sure if this is an HKS bling thing or if they are that much better. I've read that the R34 N1s are only slightly smaller than the 2530s. I would like to have a fat power band and be able to spool quickly. I have read conflicting information on the ability of the R34 N1s to put out more than ~500hp(~370Kw), although I've read some posts that say they are good for 700hp(~520Kw) at the crank. Problem seems to be most of what I've read is guys speculating not actual real world experience when it comes to the R34 N1 turbos(707160-5). However, if I am going to pay to have it tuned, I rather do so with the right turbos for my application.
I have also thought about installing either a Tomei oil pan baffle kit, a Trust oil pan upgrade kit, or a Tomei oversized oil pan(ouch this one costs bucks though) . Thinking maybe the Trust weld on oil pan kit. Somewhere I also read about using smaller orfice oil restrictors like what comes in the Tomei kit, and I also read some other stuff about having an oil line plumbed into the back of the head and I think returning to the oil pan. I already have a remote mount oilfilter setup, so I think I will go ahead and put in an oil cooler as well. I liked the idea of the ARC one that went in place of the grill just under the hood, however I was thinking since I will be doing autocross maybe I should get one that has an electric fan mounted to it.
The block I am going to have cleaned and honed and then have the clutch, crank, pistons, damper balanced. Anyone have experience with Eagle rods? do they need to be modified in any way? What about bearings, do they make a difference in who makes them?
Since the engine only has around 35k miles on it I was thinking of just leaving the head alone aside from slapping in a set of cams and cam gears. Is it worth messing with the head? I have seen some guys that had the quench(sp?) area ground out. Also I was just going to use the Tomei pon cams so I don't think I would need to reshim or change springs. Remember I am not try to be a dyno queen here, peak horsepower is not what I am after, I just want to have a fat powerband and be quick and responsive on the tracks. That's why I want to stick with twins.
Pump gas or race gas? I have read some people are getting great power out of there RB26 even on pump gas when tuned properly. Is it worth messing with 92 octane or mixing race gas with pump gas? I have heard some guys get it tuned to race gas and then turn down the boost when running pump gas. Pump gas is just easier to come by and way cheaper, but then again this isn't my daily driver. Any thoughts?
Any pointers from guys that have experience building and or tuning these engines would be greatly appreciated. I am open to suggestions, and if anyone knows of good shops that do dyno tuning in the Phoenix area that would be great also as I am not familiar with any out there.
Thanks in advance,
Tim Deesen
This is what I am thinking for a build:
Wiseco pistons standard bore
Eagle rods
ARP headbolts and rod bolts
ATI Crank damper
Tomei Poncams(not sure which ones) and Adj cam gears
Tomei 1mm hgasket kit with oil restrictors
Jun oil pump
N1 Water Pump
Greddy Intake Manifold
HKS style ex manifolds, dump pipes and collector
HKS intercooler hard pipes
HKS 3inch exhaust
HKS Twin Plate Clutch
Trust FMIC
Decat test pipe(or maybe get a good hi flow cat for the streets)
BNR34 N1 turbos (thinking about HKS 2530s)
Power FC L-Jetro
Z32 AFMs
600-700cc injectors
STR Fuel Rail
Aeromotive FPR
Apexi Air Filters
Electronic Boost controller
Nismo Fuel pump ~280 l/hr
Koyo Radiatior with electric fans
External oil cooler
Oil catch can
Am I missing anything?(other than a truckload of money ;-)...)
https://www.sau.com.au/forums/topic/123217-rb26-build-not-enough-or-too-much/
350kw is ample for a tough street car. 400-500kw is more on the competition side of things, and more likely to break such things as gearboxes & front diffs. 350kw is achievable with standard internals, and the correct combination of bolt ons. Having said that if big power is what you are after, you have probably covered everything with the exception of oil pump. I would reccomend running an external mechanical oil pump rather than the Jun or N1 pumps. There are a number of upgrade threads on this site but i doubt if there will be many with 400-500kw output upgrades. especially still running factory options such as air & p/steer.
Good luck with your build, hope to hear how you go.
Thanks in advance,
Tim Deesen
Eagle rods
ATI Crank damper
Jun oil pump
N1 Water Pump
HKS 3inch exhaust
Trust FMIC
Power FC L-Jetro
Z32 AFMs
600-700cc injectors
STR Fuel Rail
Aeromotive FPR
Apexi Air Filters
External oil cooler
Oil catch can
A stock GTR motor will not last @ 350rwkw if circuit is the use.
Street it seems to be fine. But extended RPM of circuit work seems to aid in a much enhanced death.
I've seen a number fail near or around there power. They just dont last forever.
You have some great ideas Tim... i'll go over them tonight when i get home as there is a lot of info :D
heres my quick input.
Are you talking 400-480rwkw or crank kw? Don't forget the more power you want the bigger turbos you'll need = more lag....
BOV's, stock ones are fine - Leewahs car runs 600rwkw on stock BOV's.
Spark, probably worry about that once you get over 350-400rwkw.... can probably leave it until it needs it, you'll know.
power that things start breaking? tough one depends how hard you drive it, but at a guess around 350-400rwkw things would start to break..
those N1 turbos are probably good for around 500-600hp at the crank at a guess.
Yep i'd get an oil cooler, keep those oil temps nice and low.
Baffle kit/sump ext probably worth it. depends how much track work you'll be doing.
bearings not sure about brands etc... but i belive it does make a difference...
Head, thats up to you, I wouldn't stuff around with the flow of it, maybe have it cleaned up, as in pulled down replace anything that looks a bit worn etc...
Most of us just run pulp (premium unleaded petrol - 98RON here, think you may have different ratings in the states), race gas you'll get a heap more timing/power out of, but since you're not into competition i would stick to pump gas.
hope theres at least one thing here that helps :D
avoid the N1 water pump, it pumps less water at lower RPM so its likely to increase the water temps when crusing through the hot hot arizona climate. the stock water pump would be more suitable
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
