Compression Test Results... Good Or Bad?
Beef
 Share
125psi is pretty low.
the figures seem TOO close together. if they were that low i would think there would be small variances of 3-5psi between them at least. thats my opinion rather than expert advice so just get another one done somewhere else.
I tested mine when dropping the new injectors in, it runs wiseco forged pistons that have been setup on the looser side so they do slap a tad when cold.
When I finally got around to testing the comp ratio the motor had done around 20,000km's, wasn't using any oil.
To my suprise ALL cylinders were equal apart from cylinder 3 that read 1psi different. :D
I got 153psi or there abouts I don't remember exactly but it was around the mid 150's.
So when warm and the pistons fill the bore a little better no doubt I will receive a higher reading.
So yes, equal values in every cylinder is possible. :dry:
  • Replies 50
it is possible, but at the 125psi level you'd probably start to get figures that arent so close together, let alone exactly the same.
Yes for such a low level, but it may just be the guage. Which is why the general rule is to go off variation.
Cam timing could also be out, maybe rebuilt some time with lower comp pistons, thicker headgasket.. Could be a number of things.
My Rb20DET with std cam timing saw 145psi in all cylinders, that was at 60,000km's. Cam timing does make a difference to the comp ratio.
:P When i did mine a few months ago... the first 5 cylinders were at 125 and no. 6 was at 75/80!!!
ok, is your car still running fine?
using oil?
what do people think about this?
Beef
ok.....
if i was to say..... drop a set if FORGED PISTONS into it, then i would regain my lost compression.... i gather you only lose compression because the rings are starting to wear??
yeah?
Beef
using oil?
Beef
It is running pretty good for a 5 cyl but using a bit of oil...
i put about a litre of lucas in it on the weekend and she is running good again.
It still boosts and goes hard.. emm did i mention that it smokes a shitload!! :P
It only has to last me a few more weeks till i drop a RB25 in her.. then i will re-build the RB20 to sell.
oh ok, well im pretty sure that the timing was on 22degrees when comp test was done, i have taking it back to 20degrees, so maybe it may be a litle lower/higher this time?
which way?
Tim
Um, cam timing, not ignition timing. If you want to check the cam timing you need to take the belt cover off & check that the marks on the belt match the marks on the pulleys.
oh sorry, ha ha
how would one go about adjusting the cam timing.... can it be adjusted or do i need to get another timnig belt or something?
Beef
OK just went and got the compression re-tested.....
1. 145psi
2. 150psi
3. 150psi
4. 145psi
5. 150psi
6. 150psi
so i dont know what the other F**K head was doing, maybe he tested when cold or something....
so does this sound like a better number....
maybe it will improve when i do the oil change that is past due..... and also flush it out..
what you think...
check the pic, its my baby gettin checked... :P
Nothing wrong with 150psi odd.
It was probably just the other bloke guage and or didn't give it wide open throttle.
or... maybe he wanted to rebuild your perfectly fine engine. :D
1. 145psi
2. 150psi
3. 150psi
4. 145psi
5. 150psi
6. 150psi
what you think...
or... maybe he wanted to rebuild your perfectly fine engine. :P
yeah maybe he wanted to make himself a few extra bucks.... but to eliminate teh chance of a dodgy mechanic i actually watched them do it and saw the results with my own eyes...
oh and..... what you mean by they probably didnt give it wide open throttle, they dont start the engine, they only turn it over 4 times....... its never actually running.....
Beef
Beef
Ofcourse it wont start the engine, it has no coils or spark plugs - what he means is that the throttle is flat to the floor. Apparently this is the correct way to do it, otherwise you will get incorrect readings.
um der freddy........
the way he said it sounded like he was talknig about a dyno test or something.....
WOT will allow air to enter the cylinder easier and free'er which is why the results are more accurate. not doing the test at WOT may give you readings of 10-15psi less which is what i've noticed in the past.
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
