I went up to Katoomba to take a couple of pics of the old Catalina track yesterday incase it gets torn up before I return from the UK. It seems to be doing a fairly good job of tearing itself up... bit of a shame I think.
So for those who know of it here's a couple of pics
https://www.sau.com.au/forums/topic/123255-poor-old-catalina-raceway/
  • Replies 46
Posted Images
Well i'll be damned, didn't have a clue their was an old track up in that section of Katoomba but then again it took me 6mths to realise where the swimming/gym complex was :laugh:
By the looks of those pics that track actually has a better road surface than half the side streets in the area :D
That was said too be an awsome track from the people I've spoken too about it. I think it was used last by the NSW Mini Club about 3 years ago.
We can all thank the do-gooder environmentalists for that track being closed down.
Yeah, what is the planned exact date for Oran being demolished?
i have NFI, people have been saying 1-2 years for about 3 years now.
Yeah I'm pretty sure I heard correctly from one of the boys at Ian Luff.
Lets just pray for more time!
In for SAU pocket bike championships :P
Poor Amaroo raceway - my earliest motorsport memories were from there, Dad used to take me once a month when I was a little fella :O
awwww... I wish my dad was into cars :(
I wouldn't mind a trip up there to have a look at this raceway!!!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
