Jackets... Get Your Supercool Sau Vic Jackets...
  • Replies 279
Posted Images
List updated with payments to date.
Just a reminder that you need to pay within the next week to get the pre-pay prices.
We are looking to have jackets available at the next general meeting (Tues July 18th).
:O
how about those who cant make the meetings?
We'll let you know when the jackets are available.
It is up to you to arrange to collect them - or arrange postage.
They will be more broadly distributed than at the meetings - there will be plenty of opportunity.
James
James
cool.
List updated with payments.
Please check the list to see if we have received your payment or not.
If YES, thanks.
If NOT, you need to pay by this Friday 14th July to receive the pre-pay price.
Jackets will be available at the meeting on Tuesday 18th July.
:O
Money transferred 2 mins ago so should be there by Tuesday 11th am.
I had to remove the _ from my username for one of the descriptions but not sure which one it took it from so will either be saff_cossie or saffcossie.
:O
I didn"t get it >_<
My username has an _ in it. saff_cossie. My payment wasnt allowed a special character in the field when I sent the payment online. I must not be a special guy if I can't have special characters. :(
BUMP
Reminder that pre-pay prices will finish on Friday (14/07).
Any amounts not paid by this Friday will go back up to full price.
Thanks guys,
:P
Paid, thanks Matt for reminding me :laugh:. Deposit number 2989516, for an extra small or small ;).
Can we have our name on the Jacket as well? Just a thought.
Yeah mate, I will bring a texter so you dont lose it when you hang it up with the other coats at school! :P
I think if someone ran off wearing your XS, it might be obvious it wasnt theirs and they could be subsequently aprehended!
lol
i think he might have meant embroided....probably meaning forum name
still funny though Alan:P
lol
LOL! yeah I knew what he meant mate as I have my name on a T-Shirt from my cycling club. Damn where is that man when you need him to read a post! :laugh:
BTW Dezz, I am almost as much of a post whore in this thread as you, I must have learnt from the best! :P
im buying 2 jackets, so im entitled to twice the posts ;)
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
