abo- what are these squish zones you talk about? what sort of head work? port? polish?
i was told head work was not needed for what i was after. Are there problems with using a thick head gasket to achieve 8.5 cr?
Ihave also been told that o-ringing the head and or block is noot needed for my power levels.
can someeone explain this also?
thanks simon
"The quench zones are the flat areas of the cylinder head where the piston comes in close proximity to at TDC. Pentroof DOHC cylinder heads typically have 4 quench zones at the ends of the combustion chamber. Quench zones promote more complete burning and reduce the likeliness of detonation by increasing turbulence of the fuel air mixture as the piston comes to TDC by squishing the fuel air mixture towards the sparkplug and away from the end zones of the combustion chamber. This reduces the amount of fuel air mixture near the ends of the combustion chamber where it does not completely burn, thus being wasted by pushing or squishing it toward the centrally located sparkplug where it can easily be ignited."
from here http://www.nissanperformancemag.com/january04/nerds/
Basically I'm talking about removing some material from the cumbustion chambers around the valves in particular but just generally. This means you will have a lower CR but you keep the squish zones which help with power and economy. It will cost a little more than a thick head gasket but not much and IMHO is a better solution.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
