Was looking under the bonnet the other day and figured id check the radiator coolant....to my suprise it was not green but brown and had heaps of dirt build up under the cap...ive read the threads on coolants but there isnt much on the topic.
Can you guys tell me
- which coolant should be used for a r33 skyline
- how to maintain the pressure or do u need to at all
any heap on this thread would be greatly appreciated
thanks guys and peace out
https://www.sau.com.au/forums/topic/12332-flushing-radiator/
Any std coolat is good then ther's racing type's but personally i wouldent buy them. ther´s other fun thing to throw yo' chash at.
no you dont just check tha seal on the cap to C that's whole(if not CHANGE or your car will overheat when you put tour foot down) and also check the spring.
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-222786
I just use Caltex radiator coolant.... Its supposed to be a 50/50 mix. Flush your radiator, e.g. drop all your water out (undo the bottom hose on the radiator.... I think I undid the one going to the motor as it was easier then pushed the hose down to the ground). Put the hose back on fill it up with clean water (and radiator cleaner if need be) and start your car so it runs through and turn your heater on.then once its been running long enough pull that hose off and drop that water out.... once you have done that fill up with fresh coolant and water (premix it @ 50/50 or what ever the bottle says) and you will be sure that you have flushed it.
Cheers
Sumo
P.S. Let your engine/radiator cool down before you put cold water in it as it may cause things to crack (expanding and contracting too quickly)
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-223340
  • 3 weeks later...
How do you bleed the radiator? I know where the bleeder is, but dunno how to do it exactly. Do you just fill up the radiator and leave the bleeder open until all the air bubbles escape then close it again?
Also how long does the water pump usually last? I'm just wondering if I should change it at the same time as I do a coolant flush with my upcoming 100k km service.
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-265362
Not sure of the correct way but i just filled the radiator - then with the car idleing, unscrew the bleeder right out. it will bubble and carry on for a couple of mins. keep topping up the the radiator in the process.
carefull if the car is hot because the bleeder tends to spit a bit.
hope this helps some
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-268151
  • 5 months later...
Hate to bring up such an old thread,
though wtf is the bleeder on a 32?!!?
ive just flsuhed out mine, all seems to be ok, though don't want to have risks...i looked everywhere for anything that may be it but no luck...
Only thing i could see was a nut ontop and says 'never open when hot'..
any quick answers would be great as its friday nite ;p
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-526562
if u use 33% usualy 3 years i do mine every 2 years on all my cars and its always very clean . when i let the old one out i flash the system , undo the bottom of the radiator and the screw on the engine block so it lets all of the old coolant out flash it with clean water blow all water out then fill it up again .
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-526721
SKYLINE_PAUL, u say ur water is gone muddy, i had this problem b4, firstly the best coolant to by is just nissan coolant, when u flush ur radiator outby something that kills rust, the reason why ure water is so muddy is because u had to much water not enough coolant, after u have the new coolant in make sure u check the car over the several days because u may get a few leaks , mainly the water pump, and also keep checking the under the cap over the next few weeks to see if it stays green, i had to do about 3 flushes b4 i got the nice green colour back, urn cooling system is the most important thing on ur car,
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-530254
the reason ur water is muddy is because at some stage before it had just water in it or the coolant was very old and infective , common with jap imports as they are not serviced in japan .
give it a good flush and use a good coolant ready mixed dont add any water to it . u can use any coolant as long as it is at least 33% and change it every 2 years .
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-530442
Guys, how many litres of coolant will be needed do you think?
I've got 5 litres of 60 Plus (2 Years) coolant, and it says not to mix with other coolant or water.
I just dont want to get half way through the job and realise I need more and be sorta stuck with an undriveable car?
https://www.sau.com.au/forums/topic/12332-flushing-radiator/#findComment-537079
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
