o...m...f...g... look at how long those lines go for.... 10,500rpm.... excuse me, i have to be alone for a minute
PS - anyone know wot supra that is? kinda looks like an ab flug kit, and it is on the right side of the road, but its running BFG, not nittos, so i get the feeling its outside of japan.. anyone from japan, does the scenery look like japan to u?
Edited by VB-
https://www.sau.com.au/forums/topic/123353-crazy-supra/#findComment-2278010
BTW this was posted on the yank Supraforums, heres what the owner says:
"AtomicFabio FlyBy video 1187whp 33psi
I wanted to make a flyby video since I never make them! I've taped it with my mobile phone so the quality is diharrea! Yes yes yes I know I will use my high res cam promised!
But I wanted to make a video of this glorious engine today since we're going to remove it tomorrow to install the stroker.
This 3 liters engine impressed us not only for the power that was amazing but especially for the reliability! about 14 months of HARD STRESS on it and still the compression is PERFECT and it doesn't burn oil at all and the oil pressure is the same like when it was new (bearings still perfects). Plus the titanium rods made the job PERFECTLY!
Actually we ahve been able to dyno only up to 33 psi (1 week ago) on a dyno with nice rollers with something on them that helped the grip. At 33 psi we made 1107whp with the HKS 272 cams and 1187whp with our custom cams (a GREAT gain of 80whp over the 272!)
It's amazing as with the new cams the power is still rock climbing at 10k rpms but we need tighter springs as the valves starts to float at 10400rpms (old springs too). But it was just a quick test.
The flyby video was at 33psi. Started in second gear and he pass in front of me shifting into the 3rd gear and flooring.
Asphalt was hella HOT and tires were hella hot as well and 21psi of tire pressure.
BFG DRAG RADIALS 345/30/18
Here is the video!! (SHITTY QUALITY!!!!!!!!! TERRIBLE TERRIBLE! Next time with a digicam!!)
http://www.rapidupload.com/d.php?file=dl&filepath=11033
Fabio"
https://www.sau.com.au/forums/topic/123353-crazy-supra/#findComment-2280187
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
