My chick has a GTS R33 with RB20e engine in it. The engine is an absolute toy. I was thinking of throwing a RB30 in there as they are cheap as chips and everywhere. What mods if any are required to drop it in. I'm asuming the ECU and loom will need to be changed. Do the two engines share the same flywheel? Will the trans mount bolt up if I use the original RB20e 5 speed? Sump the same? etc. Someone would have done this for sure. Please post all your comments cheers.
https://www.sau.com.au/forums/topic/123356-rb30-conversion/
if your meaning rb30e then it can be done easy as and cheep as chips.
read through this. its about r32 but it will work for r33
http://www.skylinesdownunder.com/forums/sh...ead.php?t=51129
if your wanting a twin cam swap it wont be that cheep or easy. i know as i have been through that myself with my rb30de convesion from rb20e..
https://www.sau.com.au/forums/topic/123356-rb30-conversion/#findComment-2280143
damn sucks for yous over there with all your emitions stuff.
you could put a rb30e in. swap to the nissan cam cover and nobody would ever be the wiser as it would look exactly the same as the rb20e.. just a little taller.. plus you will gain torque and atleast 10kw at the wheels..
i wish i could have put a 26head now on my rb30.. just like im wishing i had put oil restrictors in the head as well... too much damn blowby!!
https://www.sau.com.au/forums/topic/123356-rb30-conversion/#findComment-2282862
depending on the state u live in they might argue that the rb30 is too big
but put that aside im pretty sure the motor should bolt straight up to your existing box... you would use the clutch out of the rb30 aswell as the flywheel... and to drop it in you'd have to put the engine mount brackets off ur rb20 onto the rb30...
most rb30s have seen their day... unless you get a reco motor expect the annoying ticking of the lifters or just dont thrash it...
https://www.sau.com.au/forums/topic/123356-rb30-conversion/#findComment-2286729
gearbox will bolt up. use your r33 engine mounts.
the thing is tho.. who is actually going to be able to tell it is a rb30? unless they look at the engine tag on the bottom of the block... cus if you put the 20e cam cover on nobody will be the wiser. even with my rb30de the mechanic thought it was a rb25de. even tho the intake pipe just touches the bonnet..
https://www.sau.com.au/forums/topic/123356-rb30-conversion/#findComment-2286872
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
