I'm soon to buy an RB20DET auto half cut and putting it all into an n/a VL Berlina.
Now I was wondering if I just leave the n/a VL diff and it will connect fine to everything or buy an R32 GTST diff or another diff?
Also, how much if i need to buy another diff?
Cheers,
BOZZA :D
P.S.:
N/A VL diff: 25 spline 2-pinion 3.45:1
RB32 GTST diff: (insert specs here!) :)
https://www.sau.com.au/forums/topic/12336-what-diff-for-rb20det/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
