hmm you got yours already??
Wonder when i get mine. So cant wait!!
Whos puttin it in for your emsta?? n for how much?
btw can you install these yourself? Any problems??
i've heard of a few guys with very little mechanical knowledge installing these themselves, it will be pretty easy, just a bit of a pain in the ass. Have to watch for broken bolts etc, and if they do break they'll need to be drilled out. Soak em in WD40 or something similar for a while beforehand to try and free them up.
  • Replies 108
Yeah, I went and picked it up from Michael after work. I will be getting RE Customs to fit it in along with the cat back I ordered from them. Spoke to michael, he said it shouldnt be too hard to fit the pipes on, as they are specifically made for the R32/33/34. I wanted to do it myself - but I think since Im doing the whole lot I will just get a professional fit. Plus I need to get my car serviced and the new turbo timer to be installed anyway.
So after all that, it should be running a turbo back exhaust: BATMBL s/steel split dump/front + catco 3 inch large cat + Trust Power Extreme 2 cat back :(
Edit - im expecting atleast a 20rwkw increase with the whole system. Michael estimates it to be more than that - but we will see. All I know is that the increase in this system, will be more than what I was told with the x-force (which would have been 10 - 15rwkw max)
EDIT Again - REcustoms said they will do it for 900 - that price includes the price for the cat back. I will have to show them the split dump/front and cat first though - incase they might require a bit more for the install.
Edited by emsta2003
shif_tea- sweet might give it a go then.
Emsta- ahh let us know how it goes when its all in. 900 sounds alright i guess.
Edited by siddr20
hi guys
The first few pipes should be getting sent out toward the end of this week as they are being made as we speak (i dont have any stock atm, last pipe went to emsta). I have updated the list of the people whose payment has cleared in the second post of this thread. I will PM you each as your pipe gets sent out. All pipes should get sent out by end of next week, or hopefully earlier.
cheers
hi Guys
First 5 pipes went out today to the following people:
Zahos
Kozeyekan
shif_tea
blackbart
JaseR33
Next 5 or so will be Fri or Mon at the latest.
cheers
ill most likely be up for one. will they fit a non stock turbo? and what size are they? (please be 3 inch.. please be 3 inch)
cheers! james.
Mine came today and looks the goods.
So fresh, I can smell the sweet scent of mig welding.
Also, many thanks to batmbl on the packaging. Wrapped in bubble wrap, and coccooned in packing tape, that thing wasn't getting scratched or banged by even the most incompetant of delivery people.
Big thanks.
Highly recommended.
-Josh
You will get significant power increase in the top range. Thats what i have heard from friends who have got spilt systems installed.. Also helps your engine breathe which is a bonus, so more air pushing out faster= more power..
I heard up to 15-25kw increase..
HMM i wonder when i get mine??
Hope you sent some out today.. Really want it this week lol..
cheers
hi Guys
Zahos
Kozeyekan
shif_tea
blackbart
JaseR33
cheers
Hi Michael,
Did ya manage to send em yesterday? sorry mate dont mean to seem pushy just trying to arrange for everything to be fitted .
Cheers
Lee
What sort of gains am I to expect if I get these installed? Is this a significant power up mod or just to put some icing on the exhaust cake
According to Michael there should be a significant increase - and hes right. There is a huge difference IMO. id estimate and say atleast 20rwkws - but i still need to dyno it once i get a couple of more mods on.
Guest
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
