CruiseLiner Posted June 22, 2006 Share Posted June 22, 2006 hey guys im currently running my new engine in my stagea which is a jun stroker and t04z and im thinking of putting a stock rb26 into it to use as a daily and buy a cheap r31 and put my stroker engine into for drifting and motorkanas and even occasional drags. now does the r31's have much aftermarket support like finding coilovers and suspension stuff? who sells aftermarket parts for them? does the aussie 31's use the same suspension and parts as the import 31's? i dont want a silvia or 180sx as they are common as hell, and the 31 will fit my 26 straight into. how will a 31 compare to silvias and the like on the drift tracks and also in motorkanas? it will have a reliable 500rwhp+ with the t04z, but im abit worried the turbo is too big for drifting and track work due to the lag issues, anyone think this is a problem? maybe a gt30 is a better option? does anyone know if any r31 drift cars are around? any other info appreciated Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/ Share on other sites More sharing options...
fatz Posted June 23, 2006 Share Posted June 23, 2006 (edited) i like the cut of your gib rb26 into r31 = very easy i had a rb26(hr31) witha 3540 and drifted it all the time its very much a case of drive around the lag and you can drift anything plus usable powerband = gtr has that aftermarket support for r31 everything suspension (convert it to s13 gear) diffrence between a r31 and a s13 for drift is you actually have to drive a r31 to drift it... while s13's are drift cars for L platers if your seriouse just pm me i can gide you in the way of the r31 grasshopper! Edited June 23, 2006 by fatz Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280018 Share on other sites More sharing options...
fatz Posted June 23, 2006 Share Posted June 23, 2006 (edited) oh yea an i know where there is asports sedan shell thats just waiting for your engine pete nothing more sexy that rb26 power between the struts of a r31 throw in some beers and some large natural d-cup breasts and im in heaven Edited June 23, 2006 by fatz Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280024 Share on other sites More sharing options...
hrd-hr30 Posted June 23, 2006 Share Posted June 23, 2006 (edited) how bout a HR30 coupe? RB engines are an easy conversion for the 6cyl L20ET, has 4wheels discs, 16*8" on the back, IRS & the 4.1 R200 diff should take all the power you can throw at it! $4000 to a good home and I'll throw in a race seat Edited June 23, 2006 by hrd-hr30 Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280045 Share on other sites More sharing options...
D-limo Posted June 23, 2006 Share Posted June 23, 2006 Please do not put it in an Asu spec R31 .. Would be good to see a Passage GT track car.. Consider the Ceffy/Laurel option as well. Suspension is interchangable with s13. Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280182 Share on other sites More sharing options...
R31Nismoid Posted June 23, 2006 Share Posted June 23, 2006 Dont use the AUS version IMO. Coupe is the way to go RB26 into HR31 isnt as easy as you let on Pete. Being im going through it now, just as you have. Especially because Brad is using a stoker that gives some nice big rev's. You dont wanna be using the tin RB25 pan, rather i would reccomend without a doubt the much stronger and supportive RB26 one So you'll need a custom RB26 sump modified to be a similar design to an RB25 pan. Other than that its not a lot harder, its just the added cost of the sump if you dont have a spare, then you need it modified. HR31 HICAS you might aswell p|ss off aswell. So far its cost me $400 for a new rack/modified powersteering pump. Which is pretty cheap. Im yet to workout the cost for locking the rear rams off correctly. But i doubt its expensive. One other guy has used a Z31 subframe, i can link more info if you want. HR31 Diff is a simple case of take it out, and shim the thing up. Race Pace here in Melb did a custom one for me. Farken amazing it is. HR31 suspension, can convert to S13 gear. You might also find HR31 coil overs on Yahoo etc. Alternatively, look for a coupe over in Japan that already has coilovers and save the hassle all together. You will need a RB25 box, you'll need the VL/R33 yoke and modify the HR31 crossmember to suit. And a R32GTR speed sender in the RB25 unit if you want the speedo to work. HR31s also have rear end squat issues. Although, getting harder suspension does alleviate a lot of that, and squat will if anything, give you more wheelspin, easier. So its a compromise... As its less rubber touching the ground under load more suqat you have, hence you wanna eliminate some of it, but not all IMO. There is some info to get you going. Nothing else comes to mind right this second Any more questions Brad? hehe Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280863 Share on other sites More sharing options...
CruiseLiner Posted June 23, 2006 Author Share Posted June 23, 2006 (edited) hey guys cheers for all the info, i knew just the mention of a 31 and fatz and nismoid are in the thread in the blink of an eye, haha, ok to get started i dont want to spend heaps on a shell its only a drift hack and drag hack to run some good times down the strip and smash panels on the track. thats the reason i want an aussie 31, i know they dont look anywhere near as good as the 2 door hr31's but i aint a billionaire and im talking around 2k max for a shell. shit paint and dodgy panels i dont really care i just wanna be able to use my rb27 to its limit ill also be gutting the interior completely to save weight. now i havent actually checked the going rate of aussie 31's but im sure they aint as dear as the import ones. so does the s13 suspension gear still fit on the aussie 31's? so if i just buy a set of s13 coilovers they will bolt str8 on? whats the diff like for holding power and are they LSD ? or do i need a r200 gtr diff or something to handle it? do they fit str8 in the r31 diff housing or do i need to change the whole diff? how much do they weigh stock? and how much totally stripped out (one seat and a few gauges and thats it)? so the plan is so far.... r31 shell my rb27 engine get a rb25 gearbox r32 gtr speedo drive rb25 yoke modified tailshaft (which model do i use?) autronics smc ecu i got r34 brembo front calipers and dba 330mm rotors sitting in my room, will they bolt str8 on? some sort of rollcage how about the stock radiator is that ok to use? ill definately get a rb26 sump and modify it (damn i just sold my spare one about 3 weeks ago ) aussie 31's dont have HICAS do they? does the power steering pump bolt str8 on? need some slicks for the drags too as i plan on setting it up for drags firstly then later on once i run a good time ill switch it to a drift/track setup what swaybars fit? gtr/gts-t/s13??? what else is needed to get them to handle well? anything else needing upgrading to cope with the power output? thats about all i can think of at the moment... thanks again for your input, and remember i dont care if it looks shit as long as it handles and moves anyone got any links/pics of some nice 31's as well??? cheers Brad Edited June 23, 2006 by CruiseLiner Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280918 Share on other sites More sharing options...
Morgs Posted June 23, 2006 Share Posted June 23, 2006 Although your motor basically defines over capitalisation, I honestly think you are pushing the defenition by putting it in a R31. Its a dish best served cold with budget modifications. I'd really look at other applications for that motor. Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280927 Share on other sites More sharing options...
88silhouette Posted June 23, 2006 Share Posted June 23, 2006 cops arse aussie r31 lock the diff (live axle!!!) bobs your uncle dont bother with import r31 Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280961 Share on other sites More sharing options...
CruiseLiner Posted June 23, 2006 Author Share Posted June 23, 2006 honestly who gives a shit what the car is as long as it goes. ive spent a fortune on the engine and its just not suitable for daily use in the stagea (plus the 1700kg weight factor). so i want a cheap drag/drift car. i dont want to spend $8-10K just on a shell for thrashing at the track, its gonna be a track only car and for abit of fun. the cheaper the better in my opinion i paid more for the t04z then i want to spend on the entire shell, but thats because i put performance way before having a bling bling car and fancy rims/paint job wait till u see a shitty lookin r31 running big numbers down the strip then it will turn some heads 10 second quarters is the aim and as long as the driveline holds up i cant see any problems Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280975 Share on other sites More sharing options...
R31Nismoid Posted June 23, 2006 Share Posted June 23, 2006 your gonna need a $1500+ diff for the AUS R31 if you want it to last with that kinda power. KAAZ locker or similar as you cant stick an import diff into the aus spec realistically. The AUS diff is the most failure prone piece of crap ever designed. Seriously, buy a shell for 2k... you'll spend 2-3times that getting it ready. So IMO get the HR with some fruit on it already. Considering you DONT need to rego it... 6-7k and you'll be laughing. Will have the suspension already most likely. Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2280998 Share on other sites More sharing options...
CruiseLiner Posted June 23, 2006 Author Share Posted June 23, 2006 your gonna need a $1500+ diff for the AUS R31 if you want it to last with that kinda power.KAAZ locker or similar as you cant stick an import diff into the aus spec realistically. The AUS diff is the most failure prone piece of crap ever designed. Seriously, buy a shell for 2k... you'll spend 2-3times that getting it ready. So IMO get the HR with some fruit on it already. Considering you DONT need to rego it... 6-7k and you'll be laughing. Will have the suspension already most likely. wheres that welder gone Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2281008 Share on other sites More sharing options...
R31Nismoid Posted June 23, 2006 Share Posted June 23, 2006 if your welding skills are a tad rusty it wont take long to get them into practice Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2281010 Share on other sites More sharing options...
Kinks Posted June 27, 2006 Share Posted June 27, 2006 (edited) R31s make great drifters. If you want the ultimate in driveline strength put a minispool and a 1-piece tailshaft in. The axles are bloody strong, I drove a locked diff daily for almost 3 years and never had a problem (includes tight parking etc). Drifting is nowhere near as harsh as tight corners for a locker. RB26 in an R31 would make LOTS of smoke Edited June 27, 2006 by Kinks Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2290155 Share on other sites More sharing options...
Deluxe Posted June 28, 2006 Share Posted June 28, 2006 Hell yeh 31's slide heaps well....... especially if you have them setup well, Below is a pic of my mate in his a few years back Ahhhhhh Bowzer was a killa slide car back in it's day!! Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2292893 Share on other sites More sharing options...
DRIFTER Posted July 1, 2006 Share Posted July 1, 2006 what happened to that car? why can't a rb25 sump be used on a rb26? Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2301258 Share on other sites More sharing options...
R31Nismoid Posted July 2, 2006 Share Posted July 2, 2006 why can't a rb25 sump be used on a rb26? You dont wanna be using the tin RB25 pan, rather i would reccomend without a doubt the much stronger and supportive RB26 one Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2301331 Share on other sites More sharing options...
Beer Baron Posted July 2, 2006 Share Posted July 2, 2006 if it's only for track I would import a track only 32 GTST or even GTR. sell of the GTR motor ($5K there easy). whack your motor in and on balance the car will probably have cost you $3-$5K max. or even whack the motor in your stagea which will save you having to fork out for a RB26 for the stag. plus putting your motor in the GTR has no mods at all, and already has a driveline to match. if you want drive you could remove the front driveshafts etc maybe even look at a more permanent RWD solution, and for drag 32 GTR traction will be a bonus. also if you do strip it you can sell all the interior for $$$. something to think about. or buy marks aussie 31. it's already set-up for competition with cams approved cage etc. Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2301344 Share on other sites More sharing options...
DRIFTER Posted July 3, 2006 Share Posted July 3, 2006 how many failures have you seen when using the rb25 sump? Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2302764 Share on other sites More sharing options...
someonestolecc Posted July 3, 2006 Share Posted July 3, 2006 I'm going to be setting up a r31 drifter in the coming months. Won't be anything too hardcore but should do me to learn and not have fear of denting the thing... I hate it already.. f**king fridge piece of shit I miss my cefiro :\ Link to comment https://www.sau.com.au/forums/topic/123413-r31-skyline-drift-car/#findComment-2303181 Share on other sites More sharing options...
