Motorbike forums......!
d.3.v.i.l
 Share
Mark,
Perhaps we can go n do the course together...
I heard the one in Ingleburn, or somewhere near there,
Is pretty easy to pass....
Eric,
I've always wanted to get an R1, but after a few storys
I heard, not just from R1, but other big CC power wise,
I think I will just stick to a 250 only... :P
get a bike that you can fix easy cause when you get a learner bike you probably would lay it down once or twice.
If you can live with it get a crappy looking bike for a year and then get a nice bike when you get off your p's...
my suggestions are that you get a GPX or an ACROSS.... for about 3-4grand or even less if you get one that is from a private dealer.... (i fink thats the going rate rite now)
If you got the cash and wanna spend big for the learner bike you can go for a cbr or a zxr... try to stay away from the fzr, i just think its a piece of crap cause i had one and it was just a pain in the ass.... cbr's go around 5000-6000 i fink.... for a decent one that is coming out of a dealer or maybe around 5000 for out of the trading post...
don't forget that you probably would want some nice gear... so yah... around 1000 for a decent set of leathers... and another 500 for helmet. Talking about good leathers and a decent looking helmet.
So all in all it ain't cheap + fixing it when you drop it (knock on wood)
L's and P's are easy... just takes a **** load of time, bout 6 hours over the 2 days i fink....
Riding is fun... that is if you don't come off...
I think i've seen you car as well...
fark it's nice...
Yeah the pre learner tests are easy as..... Anyone could pass it.
I did ! The test is two 3.5 hour days and is for the most novice riders.... The P's test is a 7 hour full day... With a 2 hour road ride and the M.O.S.T test back at the traning facility....
I got me a Xr250 road trail bike till I get off my P's then im going for a decent road bike with some grunt ! :shake:
xr250's are great fun...
do you go trail biking alot?
i am thinking of taking that up instead of riding on the road seeing that i've always had bad experiences on the road...
what kinda bike would i be looking at if i wanted something with a bit of grunt and could go trailing with?
I heard the WR400's are alrite....
If you're new to riding - do NOT get a big bike! Until you've ridden one, you have no idea how quick they are, and the torque by itself will no doubt get an inexperienced rider into problems (lifting front wheel, going way too quick into corners etc). As an indication, with a terrible launch, my bike (which is by far not the quickest bike out there) ran [email protected], which is a shade under 210km/h, and it's only just clicked into 3rd gear (out of six). Put another way, it'll do 0-200km/h in under 11 seconds. I can tell you from experience, that the first time you crack open the throttle on a big bike, your brain will kind of scramble. It's a bit hard to explain, but it's sort of trying to comprehend what's going on. It sounds a bit dramatic, but it really can be dangerous just trying to jump straight onto a 10 second bike.
Think of it like this - a late model litre bike makes around 130-140rwhp, and weighs at most 200kg, plus rider. So with drivetrain loss (not much on a bike) it might make 150hp and weigh 300kg with a heavy rider, which gives the same power to weight ratio as an R33 Skyline with well over 700hp. Give it a wheelbase of under 150cm, making it damn near impossible to keep it on the ground, and you start to understand. I work in a hospital, and the number of times I hear people say things like "I just bought an R1, and it just looped on me, I dunno what happened" is incredible.
Apologies for the essay but this is something that is really important to me. I cannot stress it enough - DO NOT get a big bike unless you have riding experience. Forget the macho "I can handle it" stand, learn how to ride before you try to ride something quick.
Phew, now that rant is over, I would recommend a CBR250R or RR as a good first sportsbike. My brother has one, and it's a great little thing. He has run 14.5 on it, which is about as quick as a stock R33 GTS25t, and it revs to 18,500rpm, it sounds like a Formula 1 car! You can pick up a very good condition CBR250 for around $3000 - $4000 if you look around.
As for dirtbikes, I'd recommend a DR. WRs are damn good but are a race bike, need rebuilds more often as they are more highly stressed. The DR650 (I think it's a 650) is a very good offroad bike, well behaved, well built, plenty of power, and handles like a dream. You can also get a DR250 if you're not ready for lots of cubes, and they're just as good, all they lack compared to the bigger bike is the power.
Oh yeah, forums :)
http://www.gixxer.com/cgi-bin/ultimatebb.cgi: GSXR forums. I believe it's based in the US.
http://www.rrzone.com/forums: Fireblades
http://www.fireblades.org/forums/: Fireblades again
http://www.cycleforums.com/forums: General bikes
That's all I can think of at the moment :D
 Share
    • There are a few variables here, some are relevant but not critical (IMHO) to help answer your question. The two major things: 1) Ignoring anything to do with forced induction - all engines have their own natural torque curve, and it will ALWAYS roll over higher in the rpm.  There is a fixed relationship between power and torque.  When dealing with kw and nm, the relationship between them is roughly: kw = (rpm * nm) / 9549 nm = (kw / rpm) * 9549 The peak torque of an engine (without boost) will typically climb until somewhere nearish the middle of it's operating rev range, give or take a bit - then start dropping again.   The nearer the minimum and maximum rpm of the engine the steeper that drop off tends to be. 2) Boost simply increases the density of the air going into the engine, which inflates the torque at that point.  The ramp up in the torque curve you see on a turbo engine is due to the boost rising, but it's essentially just multiplying the torque you'd see if it was naturally aspirated.  The roll over you see at the end will typically be what would have always happened with the engine, whether it was naturally aspirated or turbocharged.   If the torque never started dropping then power would climb infinitely. The cool thing about this is you absolutely can tune the power delivery to suit the needs of the owner and/or the limitations of the car, and I regularly do this.    With modern turbos we've got to the point where a setup that someone may run well over 20psi of boost with could actually reach target boost well under 4000rpm if the tuner/owner WANTED to - and a lot of people seem to do this when there is actually no realistic benefit, generally it just adds a massive amount of strain to the engine and drivetrain and often actually makes the car harder to drive. As a general rule I tend to tune the boost curves for cars I tune to reach a "useful" torque level through the rev range and will often end up with a curve that ramps hard to a point, then creeps for the rest of the rev range - not to make the boost curve "soft" as such, but more to make sure its neither laggy nor pointlessly violent in it's delivery.   There have been cars I've tuned to be almost like a centrifugal supercharger (or naturally-aspirated-ish) where they actually only hit like 8psi of boost before opening the gate, then ramp up the next 10psi over the rev range... if the car is "loose enough" to drive. On the flip side I've tuned a car that had stock cams and the engine's natural torque curve fell over HARD in the higher rpm and resulted in a slightly awkward power curve to work with, in that case I actually started ramping up boost to boost torque in a way to offset the engines "NA" torque drop off... at peak rpm actually running a good 5psi+ more boost that what the "flat curve" would have defined.  This gave the owner an extra 500rpm or so of useable rev range, and had a fairly solid impact on times he was running at motorsport events due to being able to hold gears a bit longer and also falling into a more useful part of the rev range in the following gears. Here's an example of an RB in a GTSt I've done the "softened" boost curve to not pointlessly ramp straight to the max boost target early in the rpm, but still made sure it builds useful boost.  If you went in the car you'd not guess at all that the boost curve was doing anything "weird", it feels like it spools immediately and accelerates relentlessly (traction dependent) and holds to max rpm.   I don't know if you'd guess what the boost curve was doing by driving the car, or even looking at the dyno plot... but imho it suits the combination.
    • therefore on the first examples, as we see, changing cams (graph 2) influences the quantity of torque at high revs its OK for me. so a tuner can act on the wastegate via the boost controller to increase the boost at high revs? on the last example, the boost does not decrease ok, but the torque does. this can come from cams etc etc ok. but on the other curves the boost is not constant, it increases, this is what I find strange to my mind. even more so if it comes from the relief valve. sorry I'm very new don't blame me. in my mind I couldn't imagine how the boost could be higher after the spool
    • right, but fundamentally, for a given mechanical setup, you are either using all the torque (and therefore power) it will give, or you are choosing to run it less efficiently. Many tuners will have a practice of identifying peak available torque and then winding it back a couple of % for safety, but unless you are working around a very specific issue like a weak gearbox, there is nothing to be gained by making 20 or 30% less than the engine can
    • You can manipulate the torque delivery by ramping in boost gently, then throwing it all in after peak torque to keep the torque flat. It's nothing magical.
    • Tuning the wastegate to do it. That is all. Most people want the boost to not fall off like the most recent example. Those also look like dyno runs with an Auto/Torque converter setup, which does fun things to the graph. The boost tapers down like that because the turbo cannot supply the same amount of air at 7000rpm that it can at 3000 in terms of PSI. That, or the tuner has decided that it tapering off like that is what someone chose to do. IF you have a wastegate that can't bleed enough air to slow the turbine, and IF that turbo can flow enough air to feed the engine at high RPM, you get 'boost creep' which is a rise of boost pressure beyond what you are capable of controlling and/or want. None of these show symptoms of that, but if you had a run that was 20psi at 3000rpm, and 27psi at 7000rpm, it could be an example of that. Or simply that the person wanted boost later for their own reasons... The dyno graphs don't always show the full context.
