Yeah, has bought his S15.
The GTR is making 256kw at all four on 14psi. However its still running standard turbo's. Can anyone confirm? I thought maybe it would be 256Rear wheels rather than all wheel.
Thats a lot of power with standard turbo's for the boost level?
Edited by Brett_A
also from what i read, the best he did quarter mile is a 12.61(with a soft launch), i though it woulda went harder than that with 20K put into it even with a soft launch...... anyway car look swell looked after.
just get sum1 u trust to check the vehicle mechanically and for any crash history or repairs. always helps to have piece of mind, no matter who u are buying off.
20K goes along way with a RB26 and yet it still only makes 265kw??
Where did the rest of the money go? :)
Maybe he's holding back the real power figures?........go the GTR!! :laugh:
you do realise that power is not an indication of how good or reliable a car is right?
supporting mods wont make more power, but will make it more reliable. ie. sump extension, etc etc.
IT has bigger injectors, pump, cams and cam gears, power fc, new intercooler, full 3" exhaust from turbo back. It also has newer standard turbo's.
I myself couldnt see 20 000 right there either, but then again I dont know much about GTR's.
Which is why I thought I would ask you guys.
Edited by Brett_A
This engine was built using about $18000, it makes a lot more than 265kw and is has the strength and reliability to support it. So when it comes to reliability versus power, I think I realise more than most mate.
Hiiiiiiiiiiyooooooooo ;)
If he has spent $20000 on this GTR then I'd say he would have reciepts for where it went so just get him to take you through exactly what he's done to the car and that it has the right modification plates to go with it.
thats a slug power fighure for a gtr .. i only spent 8grand on new turbos n exhust i got 300kw at all wheels .. im sure his either not sure or hypin or maybe did a major engine rebuild mine cost 15grand on its on to rebuild
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
