Ive searched up couldnt find it but simple Q, can i have the boost increased to say 9psi without having a boost controller or boost guage? Reason why is Im getting a FMIC installed and wanted to up the boost, Im gonna get a PowerFC with the boost controller kit but my skyrocket is a little short (hopefully in a month or so). So is it possible to get a mechanic to just manually set it to run and have it as a temp solution?
https://www.sau.com.au/forums/topic/123443-higher-boost/
you cant increase the boost without some sort of boost controller.
you could use the accutor off a rb20 turbo to increase to approx 9psi
the spring in the turbo accuator is set at a certain psi so your mechanic cant just adjust it manually
the 2nd option is just to use a bleed valve
3rd option is to use one of they many electronic boost contollers (ebc) on the market. these are more $$ but better functions
i also found that addition of 3in exhaust and cooler increased the boost level
Edited by rb20inside
https://www.sau.com.au/forums/topic/123443-higher-boost/#findComment-2279465
