OK
I have an R32 GTR with about 300awkw – and I think my clutch may be going
I currently have a twin plate – 'cause I here it rattle every time I have the clutch on the floor (no it's not the spigot beating), but I don't have much (READ :ZERO) experience with twin plate clutches – so this is my problem.
Lately the car / clutch we will shudder (ALLOT) when moving away from a stand still – this is worst when doing a hill start. I also seem to get what I will describe and a groaning sound when the clutch is at the balance point. The groan will happen pretty much all the time when moving away from stand still (can replicate it) – and the noise is linked to engine speed not road speed. It seems to be coming from the passenger side front of the car – and is almost like a v-belt slipping without the squeal.
So – my assumption is that the clutch is about to go – yes ?
Having foolishly leapt to that conclusion (and I'm looking for confirmation here guys) what should I use to replace it with.
I know I can recondition the current twin plate – any suggestions on how much that should cost. The clutch was in the car when I got it – so I do not know exactly what sort of clutch it is.
What if I wanted to swap over to a single plate clutch – I understand that these types of clutches can easily take the power – but will I need to replace my fly wheel too. Will that be a better option. My current twin plate is OK (not too heavy) – but it's less than ideal for day to day driving.
Lastly – how much, or how many hours should it take a reasonable mechanic to swap the clutch out ?
all comments / advice and general sledging welcomed at this stage
Edited by itbmils
https://www.sau.com.au/forums/topic/123463-gtr-clutch-problems/
it shouldn't take more than about 4 hours. my mate is a mechanic and it took him 65 mins to get an r33 gts-t box out and get the clutch off. i imagine that a gtr would take a little longer. so i'd say 2 hours each way (4 hours total) would be a safe guess.
Give the guys at Direct Clutch a call. They can recondition any twin plate I've ever sent to them and a lot better price than replacing it. As for fitting it, I'm not sure if they do that as well, there will be plenty of guys on here that can help.
thanks for that
Also
I forgot to mention that I still don't seem to get any slip - I can easily break traction - even in 3rd @ speed (I just love telling people that >_<)
So - am I on the right track - or not ?
will a twin plate slip - or just die ?
Edited by itbmils
sometimes the pressure plate will start to die, then you will get slip then eventually nothing. if it's not slipping when loaded up in 4th and 5th then i wouldnt worry about replacing it just yet.
The shuddering indicates the clutch is fine its just being driven wrong. Dont ride it so much and let it out quicker otherwise it will do as you have said (and stuff the clutch fairly quickly).
Some twin plates are nice to drive, others (like the HKS one in my car) can be down right bastards. Just give it some more practice and let it out quicker rather than hold onto it at grabbing point which is whats happening.
Edited by Amaru
The shuddering indicates the clutch is fine and grabbing as it should, youre just riding it too much. Keep driving it like this and it will be stuffed fairly quickly.
Let the clutch out quicker... some twin plates are friendly, others (like my HKS one) are really bad and you have basically two options which is to stall it or wheel spin it (although I did find a point where it would start moving nicely and then just let the clutch fully go and it would be ok).
I know what you mean - mine is clearly binary (on or off) - problem is that I have had the car for almost 2 years now - and it's only started doing this in the past month or so. I don't think I've changed my driving style in that time >_<
I've been looking at some pics and visually speaking it looks like an OS Giken (spelling ??). By that I mean it's not purple or anything
I'm as concerned about the groan as I am about the shudder
any chance I could have some oil on the clutch plate or fly wheel ?
what else could make this noise ?
the exeddy clutches don't stay purple for that long.
have you given the car a bit of a raping just before it started playing up? you could've damaged/cooked the flywheel or plates. it might just need machining.
and the rattle just sounds like a throwout bearing being dry. i have a dry input bearing, and it makes the oposite noise - rattles when clutch is out, not in.
  • 3 weeks later...
ahahaha.
ive heard a story about GTRs in bathurst. they were havein problems launching it without bogging down. so they contacted nissan japan, and nissan replied. hold on 8000rpm and dump it. and stop driving like pussys
Hahhahaha Nice! ...
Can you imagine some of the Laughs Nissan Japan had at our learning Expense....
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
