OK
I have an R32 GTR with about 300awkw – and I think my clutch may be going
I currently have a twin plate – 'cause I here it rattle every time I have the clutch on the floor (no it's not the spigot beating), but I don't have much (READ :ZERO) experience with twin plate clutches – so this is my problem.
Lately the car / clutch we will shudder (ALLOT) when moving away from a stand still – this is worst when doing a hill start. I also seem to get what I will describe and a groaning sound when the clutch is at the balance point. The groan will happen pretty much all the time when moving away from stand still (can replicate it) – and the noise is linked to engine speed not road speed. It seems to be coming from the passenger side front of the car – and is almost like a v-belt slipping without the squeal.
So – my assumption is that the clutch is about to go – yes ?
Having foolishly leapt to that conclusion (and I'm looking for confirmation here guys) what should I use to replace it with.
I know I can recondition the current twin plate – any suggestions on how much that should cost. The clutch was in the car when I got it – so I do not know exactly what sort of clutch it is.
What if I wanted to swap over to a single plate clutch – I understand that these types of clutches can easily take the power – but will I need to replace my fly wheel too. Will that be a better option. My current twin plate is OK (not too heavy) – but it's less than ideal for day to day driving.
Lastly – how much, or how many hours should it take a reasonable mechanic to swap the clutch out ?
all comments / advice and general sledging welcomed at this stage
Edited by itbmils
https://www.sau.com.au/forums/topic/123463-gtr-clutch-problems/
it shouldn't take more than about 4 hours. my mate is a mechanic and it took him 65 mins to get an r33 gts-t box out and get the clutch off. i imagine that a gtr would take a little longer. so i'd say 2 hours each way (4 hours total) would be a safe guess.
Give the guys at Direct Clutch a call. They can recondition any twin plate I've ever sent to them and a lot better price than replacing it. As for fitting it, I'm not sure if they do that as well, there will be plenty of guys on here that can help.
thanks for that
Also
I forgot to mention that I still don't seem to get any slip - I can easily break traction - even in 3rd @ speed (I just love telling people that >_<)
So - am I on the right track - or not ?
will a twin plate slip - or just die ?
Edited by itbmils
sometimes the pressure plate will start to die, then you will get slip then eventually nothing. if it's not slipping when loaded up in 4th and 5th then i wouldnt worry about replacing it just yet.
The shuddering indicates the clutch is fine its just being driven wrong. Dont ride it so much and let it out quicker otherwise it will do as you have said (and stuff the clutch fairly quickly).
Some twin plates are nice to drive, others (like the HKS one in my car) can be down right bastards. Just give it some more practice and let it out quicker rather than hold onto it at grabbing point which is whats happening.
Edited by Amaru
The shuddering indicates the clutch is fine and grabbing as it should, youre just riding it too much. Keep driving it like this and it will be stuffed fairly quickly.
Let the clutch out quicker... some twin plates are friendly, others (like my HKS one) are really bad and you have basically two options which is to stall it or wheel spin it (although I did find a point where it would start moving nicely and then just let the clutch fully go and it would be ok).
I know what you mean - mine is clearly binary (on or off) - problem is that I have had the car for almost 2 years now - and it's only started doing this in the past month or so. I don't think I've changed my driving style in that time >_<
I've been looking at some pics and visually speaking it looks like an OS Giken (spelling ??). By that I mean it's not purple or anything
I'm as concerned about the groan as I am about the shudder
any chance I could have some oil on the clutch plate or fly wheel ?
what else could make this noise ?
the exeddy clutches don't stay purple for that long.
have you given the car a bit of a raping just before it started playing up? you could've damaged/cooked the flywheel or plates. it might just need machining.
and the rattle just sounds like a throwout bearing being dry. i have a dry input bearing, and it makes the oposite noise - rattles when clutch is out, not in.
  • 3 weeks later...
ahahaha.
ive heard a story about GTRs in bathurst. they were havein problems launching it without bogging down. so they contacted nissan japan, and nissan replied. hold on 8000rpm and dump it. and stop driving like pussys
Hahhahaha Nice! ...
Can you imagine some of the Laughs Nissan Japan had at our learning Expense....
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
