Hey fellas, as i had my car on the hoist the other day i noticed i had pretty bad camber wear on the inside of my back tyres.. And considering the prices for 18 x 10 265's are not cheap! I called Pedders and the quoted me $190 per Camber arm + fitting... a total of $530! it was a joke honestly... I love the way it sits but it will cost me too much on the long run with having to change tyres every 6 - 12 months
Can anyone please recommend what else i can do to get my camber problem fixed?
Regards,
Sarkis
https://www.sau.com.au/forums/topic/123495-camber-wear-on-tyres-help/
JJR Rear Upper Adjustable Control Arms Price: $149 (Pair)
Suit Skyline R33 GTS-T, S14 & S15
justjap.com
hope that helps
Ed
My only concern with aftermarket suspension arms is the issue it may cause over the pits or insurance should one have an accident. For offroad use.. fine.
unless these items have been approved?
Grab the whiteline items, you can't go wrong.
I have series2 R33. I puit the whiteline adjustable arms on it. gave me what i needed and seems good quality (saw some cheap imported stuff that scared me) If to expensive. Superpro or probably even Whiteline will do camber adjustment bushes, but doubt you will gety same amount of adjustment.
Regards
R Dirty 3
Regards,
Sarkis
Whiteline camber kits on the Group Buy as follows;
http://www.skylinesaustralia.com/forums/in...showtopic=85467
Excessive negative camber is directly related to height. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Note that 350/340 is the best height for handling and ride comfort
:) cheers :P
Hi i have seen rear camber kits for R33's on Ebay for a $149 a set .. Besides i wouldnt go to pedders any how they are over priced and over rated in their products check out the link..
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
Regards,
Sarkis
Sorry to hijack the thread, but i got wear on mine, but it is only the inside inch, enough to blow my tyre any ideas??
Whiteline are in sydney dude. Give them a call direct if you arer intereseted in their control arms. Becareful of some of the cheaper arms on the market. Quality is pretty low and i would not like to find out what would happen if they failed at 100kph on freeway.
Regrds
R Dirty 3
go to a tyre or suspension shop and get them to match the toe to the camber. that will greatly reduce the tyre wear.
All that means is instead of wearing the tyres out fast only on the inside, it wears out the whole tread fast. It’s a band aid, the proper answer is to fix the excessive camber
:ermm: cheers :(
Had my car up on a hoist today and took some pics. I have tein adjustable (height and damper I believe) coilovers and this is what my rear tyres look like.
Is it bad wheel alignment etc or just this camber issue?
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
