Had my car up on a hoist today and took some pics. I have tein adjustable (height and damper I believe) coilovers and this is what my rear tyres look like.
Is it bad wheel alignment etc or just this camber issue?
Thats definitely some bad tyre wear.. All though not as bad as my old VS 5ltr that had IRS and lowered on bilstein gear. The first set of tyres only lasted 5,000km's, the outside was like new, the inside was like yours. I was very pissed.
  • 3 weeks later...
Found out mine was due to the previous owner running the tyres under pressure, and destroying the inside of the sidewalls, causing the tyre to lose strenth, guys at the tyre shop had never seen it so bad. At first they couldnt figure it out, coz i only had 1.8 neg and to get the wear i would have needed at least 10(holy shit) But we got to the bottom of it
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
