BeAgLe Posted June 23, 2006 Share Posted June 23, 2006 Hey, I just found out today that my R34 GTT has been fitted with a HUGE aftermarket oil cooling system that i didnt even know about! My mate showed me some pics in a mag of a stock R34 GTT oil cooler setup and asked where mine was and I got very pissed off that my car didnt have it. Then we took a look under the bonnet to double check that it definately wasnt there. I asked him where all my oil lines were and he searched but couldnt locate. Then he stepped back in disbelief and pointed to what i thought was my radiator. He went and grabbed his mags again and compared my car to the stock photos. It turns out my car has a HUGE 600mm oil cooler infront of my radiator along with an electric thermo fan bolted onto it, then my radiator sits where it should with another thermo fan bolted onto the other side. Then after closer investigation, it seems i may have a larger than stock radiator also... mine has a "CALSONIC" radiator with a chromish sticker saying "74" on it, but all the pics of the stock radiators in the mags had "71" on their sticker, so my mate thinks it may be a larger one... it also has nissan stampped into it... so we are not 100% sure. This got me thinking more about my car, as I imported it directly from Japan only a few weeks ago, but I was told i was purchasing a fully stock one, but when it arrived, it was modded up nicely. When i got the car home and got fomfortable with the handling etc, i switched my electronic boost controller over to high boost and planted it, and to my horror, the boost guage in the dash which use to go up to .5 bar (7 psi) shot up past the 1.0 bar (14 psi) line and stopped at the end of the guage. I thought i had blown the engine or something but then tuned it back to run 12 psi on high boost for safeguarding the engine till i know what is going on etc. Would it be possible at all to run at least 1 bar (14+ psi) using my stock injectors/computer etc??? I thought they were limited to 14 psi then they get a fuel cut to prevent damage etc? What would i need to do to see if i have larger injectors and an aftermarket computer without pulling the engine and car apart????? Any help / comments / info would be greatly appreciated! Thanks. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/ Share on other sites More sharing options...
Stel Posted June 23, 2006 Share Posted June 23, 2006 14 psi is basically the limit for stock computer/turbo etc. Anything after that your pushing the life of the turbo and the computer will rich and retard. To check if you have an aftermarket ecu go to your passenger seat and just to the left of were your left leg would usually sit in the footwell there will be a kickpanel. Take the panel off and the ecu is under there. If it says Nissan its more than likely that is the stock computer. The most common ECU change is to the Apexi Power FC so it may have one.... how did the car feel when you gave it a boost at above 14 psi? was it sorta spluttering? Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281088 Share on other sites More sharing options...
D-limo Posted June 23, 2006 Share Posted June 23, 2006 lol the oil cooler you speak of is your aircon.. Your rad is stock too. Calsonic make lots of stock parts for Nissans. Sorry to rain on your parade.. : Check if your ECU has been chipped.. I wouldn't go boosting around until you have someone check your AFR's Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281096 Share on other sites More sharing options...
BeAgLe Posted June 23, 2006 Author Share Posted June 23, 2006 Drift_Limo - Ok, thanks for that! So the pics in the mags were of GTT's without air con? Or was that fitted as stock without having to be an option? Why would i NOT have a oil cooler then, because there is plenty of room there where it should be... And my oil temp never rises much above the line BELOW half way (about 100 degrees i think it sits at when completely warmed up) It stays there from the long drive from Sydney and when i give the car a bit of a flog... I'll check about the ECU tomorrow in the kickpanel. Stel - No, the car felt and sounded fine at high boost (1 - 1.5 bar) and just kept pulling... More info/comments would be good! Thanks for the replies! Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281101 Share on other sites More sharing options...
D-limo Posted June 23, 2006 Share Posted June 23, 2006 (edited) I'm unaware of any skyline that has an oil cooler standard?? Could be wrong. Oilcoolers don't need thermo fans I know that much. You'll find that most Nissan imports (and others) run the same or simular configuration with the aircon condensor thingo infront of the radiator. Your car shouldn't overheat with a bit of a thrashing.. It's a freakin R34!! They are designed for the occasional thrash Also don't rely on stock temp gauges.. Though yours would be credible as its fairly new. Wich magazine are you referring too? Edited June 23, 2006 by Drift_Limo Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281112 Share on other sites More sharing options...
BeAgLe Posted June 23, 2006 Author Share Posted June 23, 2006 (edited) Drift_Limo - I just checked the kickpanel and it IS a factory computer It was a recent (even latest?) copy of either FastFours or Hot4s mags. I'll double check tomorrow coz its my mates mag. Only reason we got into investigating my car in the first place was because of the oil cooling guide in it. They recommend an oil cooler but then have pics of a stock R34 GTT as a sample WITH one fitted as stock they claim... I just had a look of some other R34 GTT pics i have saved and none of them seem to have the oil cooler fitted either... maybe it was a typo in the mag and they meant to say R34 GTR? Anyway, on the subject of aftermarket computers, would you recomment a microtech or power fc??? I found microtechs for $1450 and power fc's for $1349 so im leaning more to the power fc moneywise (only $100 i know), but have heard microtechs have more in-depth capabilities of tuning and have more functions, and are more commonly able to be tuned by more people than the fc... Thanks all. Edited June 23, 2006 by BeAgLe Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281120 Share on other sites More sharing options...
BeAgLe Posted June 23, 2006 Author Share Posted June 23, 2006 I also forgot to mention the reason why i was going into the temp guage is because the guide in the mag said its common for a mildly tuned car's oil temp to sit around 120 - 130 degrees and thought that mine was sitting 30 degrees lower due to the large oil cooler... ??? My car is a 1998 model, but yeah, all the guages read fine and are quite resposive quickly... Is there any way of getting rid of that annoying 180km/h speed restriction, or do you have to replace the computer? Thanks again. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281123 Share on other sites More sharing options...
NJR 34GTT Posted June 23, 2006 Share Posted June 23, 2006 Definitely not safe if any of the supporting systems are stock. Although I'm surprised you didn't hit boost/fuel cut which kicks in around that level. And if it is stock, you won't be making anymore power at 14psi than at 11-12psi because the turbo is far out of its efficiency range. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281129 Share on other sites More sharing options...
WazR32GTSt Posted June 24, 2006 Share Posted June 24, 2006 post up a picure of this supposed oil cooler setup you have.. R34's do have an oil cooler as standard - saw a picture and read an article in the latest hot4's magazine Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281312 Share on other sites More sharing options...
n15m0 Posted June 24, 2006 Share Posted June 24, 2006 is your GTT auto?? if it is...it may be the transmission cooler...also located in front of the radiator...manuals don't have this... Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281417 Share on other sites More sharing options...
BeAgLe Posted June 24, 2006 Author Share Posted June 24, 2006 Hey, The photos in the mag i am talking about are in Hot4s Mag Issue 139 (Latest issue) on page 151. I have a MANUAL R34 GTT and i do NOT have the small looking oil cooler they claim is standard so i dont know what is going on. I cant even see any oil lines or brackets anywhere for where it MIGHT have been... lol. Any suggestions? Thanks. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281439 Share on other sites More sharing options...
ferni Posted June 24, 2006 Share Posted June 24, 2006 Don't think any skylines GTR or gts, gtst, gtt came with oil coolers. If you give your car a thrash on the street you'd struggle to get it over 100-110 deg oil temp, on the track you could get it much hotter. For street driving don't think you need an oil cooler, for track, you definatly should have one. Wouldn't belive what they write in HOT4's.... Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281444 Share on other sites More sharing options...
GTRgeoff Posted June 24, 2006 Share Posted June 24, 2006 Hot 4's doing stories on Skyline 6's. Either they have no stories or are just envious. Still they should stick to their rice. And you have a real car so don't need to read their crap. The info on here is more reliable anyway. Just enjoy your car for a little while until you learn what the right mods to make are, then take it to a reliable workshop. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281592 Share on other sites More sharing options...
sewid Posted June 24, 2006 Share Posted June 24, 2006 haha that magazine is wrong but it's not the first time one of those kinds of mags were blatantly wrong. Some GTR's came with oil coolers from the factory, and it was an option for sure on the R34 GTR and probably the others. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281709 Share on other sites More sharing options...
Abo Bob Posted June 24, 2006 Share Posted June 24, 2006 Strange thread. Post pics mate. GTT's do indeed come standard with an oil cooler but it's not like you think. There is a device that is plumbed in between the block and the oil filter that is also plumbed into the cooling system. This is an oil cooler... of sorts. Also, take it to a dyno and get it checked out before you run ANYTHING other than stock boost. You could very easily blow your engine or your turbo. Generally, get someone who knows what they are looking at to have a look for you instead of trusting hot4's. Go to a cruise with some of the SAU QLD guys. Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281832 Share on other sites More sharing options...
Bluprint Posted June 24, 2006 Share Posted June 24, 2006 (edited) Here is a pic of the oil cooler that Abo Bob's talking about ('scuse the weird angle, the Neo was hanging in mid air halfway into the engine bay when the shot was taken) It's the bronze-coloured cylindrical object to the left of the oil filter. I've also seen them on RB26's and R33 RB25DET's. Edited June 24, 2006 by Bluprint Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2281907 Share on other sites More sharing options...
Trust33 Posted June 25, 2006 Share Posted June 25, 2006 Bluprint i like the sig...lolz Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2283847 Share on other sites More sharing options...
PHATR32 Posted June 26, 2006 Share Posted June 26, 2006 The N1's defiently came with and external oil cooler. steve Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2284738 Share on other sites More sharing options...
BeAgLe Posted June 27, 2006 Author Share Posted June 27, 2006 Hey all, Here is a pic to show you what i mean... [see attachment] There is no "stock oil cooler" on the left... and the chrome sticker on the radiator has "71" on it where the other 5 or so R34 GTT's I have seen had "74" on them. See on the right how there is a thermo fan connected to what looks like a cooler or some sort which has been determined to be something for the air con... Comments? Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2288304 Share on other sites More sharing options...
Bass Junky Posted June 27, 2006 Share Posted June 27, 2006 That's the Air Con Consender. Sorry. GTTs DO NOT have a standard oil cooler of any type. you WILL require an oil cooler of some description, proper type, mounted in the driver side of your Nismo front bar if you want to do any type of track work. BASS OUT Link to comment https://www.sau.com.au/forums/topic/123521-hidden-extras/#findComment-2288332 Share on other sites More sharing options...
