just wanted to say i went to a well known workshop the other day to get a new clutch fitted and they charged me $1000 in labour!! I supplied the clutch, it was a straight in and out job.. y on earth it took 11+ hours is beyond me? also i had to fork out for a new gear boot that was fine 2 days before hand as i had it off doing some work..
I wont flame here.. pm me if you want to know
https://www.sau.com.au/forums/topic/123522-my-new-clutch-install/
  • Replies 46
It's not hard at all.. especially if you have a hoist to give you plenty of room to maneuver, and all the other professional tools that a workshop should have. I'm a complete amateur and I could do it in around 5 at the most.
did mine in 3 plus machining flywheel too
I actually do them in 2 hrs if the other guy I work with machines the flywheel while I clean the box up.
GTS4 and Series 1 32 GTR's take an extra 10 minutes because of the extra shaft to remove.
Series 2 and up are a little more tricky because of the pull type setup they have but it isn't much more difficult if you've done it before.
I'd say the workshop that did it didn't know it was a pull type and had major issues removing the box. Still, they are wankers for chargin you for their incompetence. If you had a GTIR pulsar I'd say they did you a favour by only charging 11 but a 33 GTR should be no more than 4.
I did my first R33 gts clutch on the floor of my garage with one jack and low car stands - it took less time than that and we struggled with bugger-all tools and took hours to get the top bolt off.
I would've asked the workshop where their hidden cameras were....Thats a joke. Please post here which workshop it was.
NOTICE: You're not defaming them - simply quoting what they said the bill was.
Adrian
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
