My New Clutch Install
azamataz
 Share
just wanted to say i went to a well known workshop the other day to get a new clutch fitted and they charged me $1000 in labour!! I supplied the clutch, it was a straight in and out job.. y on earth it took 11+ hours is beyond me? also i had to fork out for a new gear boot that was fine 2 days before hand as i had it off doing some work..
I wont flame here.. pm me if you want to know
  • Replies 46
yeh i told them i wasnt paying it and eventually got them down to 5 hours labour. But still they should know what there doing. I dont know how to change a clutch but i bet i could have done it in less time
It's not hard at all.. especially if you have a hoist to give you plenty of room to maneuver, and all the other professional tools that a workshop should have. I'm a complete amateur and I could do it in around 5 at the most.
did mine in 3 plus machining flywheel too
I actually do them in 2 hrs if the other guy I work with machines the flywheel while I clean the box up.
GTS4 and Series 1 32 GTR's take an extra 10 minutes because of the extra shaft to remove.
Series 2 and up are a little more tricky because of the pull type setup they have but it isn't much more difficult if you've done it before.
I'd say the workshop that did it didn't know it was a pull type and had major issues removing the box. Still, they are wankers for chargin you for their incompetence. If you had a GTIR pulsar I'd say they did you a favour by only charging 11 but a 33 GTR should be no more than 4.
I did my first R33 gts clutch on the floor of my garage with one jack and low car stands - it took less time than that and we struggled with bugger-all tools and took hours to get the top bolt off.
I would've asked the workshop where their hidden cameras were....Thats a joke. Please post here which workshop it was.
NOTICE: You're not defaming them - simply quoting what they said the bill was.
Adrian
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
