Bump.
Come on guys I need to know if its necessary for my engine to run.
From what I can tell my after market computor isnt even plugged into it anyway.
Do I need to plum it in or not?
What throtte body are you using?
:D cheers :wub:
Im using an XF throttle body and also my computor dosent run a throttle position switch/sensor.
Its an EMS stinger if that helps.
The common solution is to use a throttle stop on the XF throttle body to control the idle rpm and piss off all of the ECU controlled idle speed hardware.
:D cheers :wub:
I ran my rb20 without it for a year or so. Started and idled fine, it would just stall approaching the same speed hump every morning :D
So i got in the habit of clutch starting it once past the speedhump and it was happy to keep going after that.
:D cheers :wub:
Could you please elaborate on this sydneykid?
Are you saying not to run any of them including the two on the back of the plenum?
Thanks.
Thanks.
You need to talk to your EMS tuner, as to how he wants to control the idle rpm. The standard RB20/25 throttle body closes completely. So the standard ECU (and Power FC) controls the idle rpm by opening and closing various valves that bypass the throttle body. So when it is cold the ECU advances the ignition, richens up the A/F ratios and increases the airflow into the engine to increase the base rpm and give stable idle. Similarly, when the engine is up to operating temperature, the ECU increases the airflow into the engine to increase the rpm for air conditioning, power steering and electrical load.
I haven’t studied the idle control circuitry in great detail, but my simplistic understanding is the ECU open up various different sized valves depending on the idle speed demand for air flow. This is different to many other engines that use a stepper motor to open the throttle butterfly to achieve the airflow changes required.
The EMS’s that I have dealt with don’t have the feature of staged valve openings to control idle to a number of preset rpm's. So the tuners tend to use a throttle stop to hold the throttle butterfly open, then use A/F ratios and ignition retard/advance to achieve idle stability, hot or cold.
So talking to your tuner is always first on the list when looking at idle speed control
:D cheers :wub:
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
    • Nice ride, hard to find these days!
    • Full e85 barrell stuff real world for reference if it helps as Ive pushed 2 x sets injectors to limit Above mentioned Bosch 1480cc run on 4 bar base to the apparent 1650cc on rb2.7 yielded 912hp / 684  kw  at 92% duty on hub dyno ID1700's - RB 2.8 ...1015hp / 760 kw at 87% duty - hubber dyno + shown off data on track my opinion IF you change injectors just go bigger than you think you need the modern/ good larger ones run just fine if tuned properly even if way bigger than required even on streeters
