Killometer's: Engine rebuild and put in 1000kms ago, body done 22x,xxxkms
Manual or Automatic transmission: Manual
Engine Type: 16v 100kw from Jap Spec AE92
Road Worth Certificate: No RWC but can supply
Registration: Expire on March 2007
Modification:
Bigport Intake Manifold with T3 Adaptor plate to suit small port
TRD 0.8mm Headgasket
HKS Intake Cam 256 degree duration
Custom Adjustable Cam Pulley
New Exedy Heavy Duty Clutch
New 3.8KG 200mm Flywheel
RSR Jasma 4-2-1 Stainless Extractors and catback
Std T50 Gearbox with JDM Bell Housing (keep the slave cyclinder cool)
Front and Rear Strut Bar
Tokico Shocks
Cusco Camber Tops
30mm NRCA
TRD Front 8kg Springs
TRD Rear 6kg Springs
Rebuild JDM Calipers
RDA Slotted and Vented Rotors
New Brake pads
ADR appoved Braided brake lines
JDM Cluster
Whiteline Tailights
Sparco Pro2000 Fixed bucket seat Driver side with Sabelt Harness (bought $1200 when new, FIA Approved)...
Recaro Replica Passenger side
JVC MP3 Motorized Headunit...(bought $1000 when new)
JVC 4' Splits at the front
Kenwood 4 Channel Amp
Sony X plod 6X9 Speakers at the Rear
MTX 12' Subwoofer
Central Locking with Alarm
Extras:
5 point roll cage freshly powdercoated into orange, a complete running T18(use the diff in the T18 replace the sprinter diff and put in a LSD u got urself a drifter)
$10,000 or
$6,500 without stereo, with std suspension and brakes and i will keep the cage and T-18.
Will consider swap with similar value cars.
cheers
https://www.sau.com.au/forums/topic/123585-melbae86-white-4age/
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
