Okay, my baby is up for sale, just bought a forester GT (need a more practical car). Car has been well looked after for the last 3 1/2 years since I bought it as a fresh import. Serviced every 5000km with synthetic oil etc. Now has 129000km. Only really driven on weekends for the last year. Car is in extremely good condition. Has never missed a beat. Mods as follows:
Full 3" exhaust turbo back
rb25 turbo (only been on 2 weeks)
600x300 front mount intercooler
turboXS bleed/ball spring valve
pipercross panel filter with custom CAI
bilstein shocks (circlip adjustable)
King springs
whiteline adjustable front and rear sway bars
whiteline adjustable front and rear camber kit
whiteline adjustable caster kit
whiteline subframe lock kit
strut brace
GMAX H050 17"x8" front and 17"x9" rear with 235/45 and 255/40 Hankook k104's (70% tread)
HD clutch
Redline gearbox oil
Bosh 044 fuel pump
new Nismo leather gear knob
new leather gear and handbrake boot
Pioneer CD player
6" pioneer speakers front, 6" JBL splits rear
12" pioneer sub
Kenwood 4 channel amp (for speakers)
Altec 2 channel amp (for sub)
window tint
cruise control
GTR front Bar with N1 scoops
GTR rear spoiler
Car made 168rwkw on a 40+ degree day with stock turbo, on a low reading dyno, has not been tuned since the rb25 turbo has gone on, but definately pulls harder.
Price $15 000
Located in Adelaide, Northern Suburbs.
Contact Rob on 0408817266 (after 7pm weekdays) or via email [email protected]
https://www.sau.com.au/forums/topic/123587-r32-gts-t/
  • 4 months later...
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
