Hi everyone,
As the title suggests, i need to sell my R32 GTS4 sedan as soon as possible!
My stagea is on the way from Japan, so i need this gone!
It's a 1989 HNR32 (gts4) sedan, RB20DET (4WD), 5 speed manual, with about 112,000km's on the clock.
It's in great condition, drives very well, reg expires next january.
This car has been very well cared for since i imported it in late 2004. It's mechanically excellent, and the body is also in very good condition with no rust to report anywhere.
Only modifications are a 3" exhaust from turbo back, and an upgraded garrett turbo. The car has recently had a roadworthy certificate done (about 2 months ago), and also has passed EPA testing.
*** Price drop to $9,000 ***
including plates, roadworthy (i'll get a current one once i have a buyer), and reg.
Price is slighty negotiable if it means a quick sale! - Tell anyone you know who may be interested!
Any questions, give me a call 0407 856 896 or email [email protected]
Cheers!
Leigh.
Edited by blackfink
 Share
    • shannons wasnt far off what i was paying tbh. so i will check out Lumley and i dont track the car at all. but yer this is definitley a 2020 Nissan Skyline 400R and yer im sure i will have trouble telling my insurance i have a Q50 RS simply because its not the car i have even though its the same build. and yes i did buy it from a dealership.
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
