All EDGE products besides the 25W50 are judged as 'Fully synthetic' by the boys at Castrol althought the API Group III and IV compositions may vary throughout the range. This could explain the price differences.
I also wonder what Cubes means by tunnelling in reference to oil filters.
Oh SANDY, I wouldn't change the oil filter. Just leave it until the next time you do another oil change! No point throwing it away..
Yer no point changing the filter...
Its just that I would tend to steer clear of the ryco's after I cut one open. :D
What I mean by tunneling is the filter media in sections blows open while the other pleats of the media stay close together.
The oil then only flows through these blown open sections of the media.
I got the word tunneling from doing a little search after I cut the filter open as I was a little concerned how the media looked.
This isn't the link I origionally found but it fits the bill... Has pics also. :nyaanyaa:
http://www.aus-cartalk.com/auspoc/techstuff.htm
So, for a 33 GTST that rarely gets a good opening, majority of trips are short (about 5-10kms) and pretty much doesnt get driven all that much, would the 10-60 be too thick?
Because i am using the 10-60 in my car now and i find that 2kms down the 5km trip, the temp on the my car has only just started to climb.
So would the 5-30 be a better go? Also would it handle the once in a long while thrashing and the occasional longer trip about 100kms?
yes, the tunneling is a problem. i only used genuine nissan filters in the past, but now use nismo veruspeed ones, or Greddy ones. also tried sard one, and power enterprise mag II.
lol they sound like rice filters. are u sure they arent rebadged rycos k&ns or something? why did u change to using them (apart from perhaps picking them up cheap from somewhere)
well I changed from using Genuine nissan filters for 2 reasons:
1. the greddy, nismo etc, claim increased flow and stronger relief valves (important as i run high oil pres) and some have magnets inside too, and I bought a whole lot in japan for reasonable price.
2. they are nicely coloured and say stuff on them like "Nismo" or "Greddy racing" etc and being mounted up high on my Grex remote filter mount presentation is important.
so yes, they are ricey. :P
nothing wrong with genuine nissan filters, and if i didn't have a fair stock of these I would use them instead.
I have heard of oil filter tunnelling supposedly being a problem, but logic tells me that it isn’t really a problem at all. My reasoning;
1. If the convolutions bow out, the theory is the oil finds the path of least resistance and flows though that area. But that assumes that the bow out area has the least resistance, but logic (and testing) tells me it doesn’t. It’s the same thickness filter media, same filtering specification, so why should the resistance be less? The answer is, it isn’t less, it’s exactly the same.
2. If (for some reason that I can’t logically determine) the oil does flow through the bow out area, it will eventually be contaminated first by the filtered particles. Hence it will no longer be the path of least resistance. Then the oil will simply flow though the other parts of the filter media. ie, one part of the filter will get dirtier quicker. So what? Natural hydraulic flow will ensure that happens, regardless of any tunnelling.
3. The dirty oil caused by tunnelling also tests my logic, why would the oil be dirtier when it flows though the tunnelling area? It’s the same thickness filter media, same filtering specification, so why should the filter quality be any less? The answer is, it isn’t less, it’s exactly the same.
So, until I see something that contradicts the logic, I am not inclined to believe that tunnelling is an issue.
:D cheers ;)
I'd give the 5W30 a go. Since your car doesn't properly warm up, the 10W60 will still be very thick. I wouldn't be suprised if your fuel economy was a little better with the 5W30 too.
  • 3 weeks later...
Nothing will "happen" as such. You may notice better fuel economy/engine responsiveness or less noise on cold starts... *depending* on what you've been using in the past. It should also easily go the distance. Ie 10,000km oil changes, providing you don't do track days etc.
you should encourage people to change their oil every 5000km or every 6months whichever comes sooner. The oil might be alright for 10k but i'm sure most people drive pretty enthusiastically so it can only be good for the car to have more frequent oil changes :)
i change mine every 4k no track days but i do enjoy the touge action :)
anything over about 3grand or max oil pressure most of the oil is diverted through the relief valves. (all 4 of them)
all oil filters use the same media. if its a paper one. they atre made to meet cirtan industry standards.
the diferance is the "anti drainback valve" and the sealing flange gasket material.
yeah castrol egde prducts are as follows..
edge ow-40=castrol slx (synthetic)
edge 5w30=castrol txt softec " "
edge 10w60=formular R " "
edge 25w50=GP50 (mineral)
they were re labled to apeal to the younger car enthusiast.
i change mine every 4k no track days but i do enjoy the touge action ;)
Well theres no problem changing out the oil sooner besides a lighter wallet. But half one of a synthetics's big advantages is because they have the capability of handling longer oil intervals than mineral oils. Take a look in USA for example, they market M1 "EP" which is guaranteed for 15,000 *miles*. So I believe 10,000km is suitable for most engines using a good quality synthetic, providing they are in good condition, don't run excessively rich or have heaps of blow by or don't see track use. Looking at hundreds of posted oil analysis's over the few past years has provided me with this conclusion. Remember just by looking at the oil doesn't really tell you anything.
If you want to drain out $90 every 6 months by all means.. just seems like a bit of a waste thats all.
T04GTR, I'm very sure oil filters do not use the same media. Sure they are cellulose but its like saying all engine oils are the same because they are liquids. There are definitely the better and worse ones out there. Also I don't think EDGE 5W30 is TXT softec because it does not have all of Softec's OEM approvals eg BMW-LL 01... unless you can find some data to prove otherwise but yeah.
Edited by Busky2k
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
    • Looking good man, dash mash is smart to ensure you don't get the dreaded bubble.
