Are There Lifter Clearances?
RB25DET motor.....
Are there specific clearences between the hyd lifters and the cam lobes when installing?? If so, how do you adjust??
I don't think there are any clearences for these but I could be wrong..
Just getting tapping when cold but engine is only 13,000kms old... Same springs and recond hyd lifters so I'm thinking I've got a suspect lifter or 2...
Maybe a spring... only does is when cold though.... on idle and when the needle passes the 2grand mark, anything above 2grand, and no tapping....
What do you think?
I understand what you're getting at but I've been using the same oil as soon as I caqme off of the running in oil.... It's the Motul 4100 Turbo light.... good stuff, I don't think it's the oil....
When I'm warming up the car and the needle is pretty much at operating temp (2/3 of the way up), the idle knock goes away but it will still do it right on 2 grand, but won't tap either side of it..
I do have forgies, could it be piston slap? I've never experienced piston slap so I'm not sure what it's supposed to sound like....
could be piston slap, if it does go away when warm, id bet on that.
bogcock was on the money if you had a stock internal setup, but forgies are renound for being loud when cold
 Share
    • I want someone to make side skirt extensions. But by 'extensions' I mean running from one side of the car to the other, forming a flat undertray, maybe one that runs to the front and rear of the car too
    • Meh, maybe the JSAI ones are FG not CF. But, given that I'm not convinced any of these look any good, it hardly matters.
    • Got them in the other day. I can confirm the r33/r34 nozzles (B8K30-AA000) are the exact same. Hope this helps anyone else that comes looking for it
    • Yeah, I should state I have no overheating issues except when it's sitting idle, with AC on (and only then) and only on VERY VERY hot days. And it stops if I turn the AC off. But I put a lot of effort into making this thing run like a regular car, I want the AC to work when I want it to work. I need no excuses as to why I should make some other thing a daily! And tbf, the thing does heat soak pretty bad, not much I can do with the exhaust running under the driver's seat, you can feel it through your shoes/pants when you step out of the car, too. Point being, aircon inside the cabin is on pretty frequently. I did think about removing heater hoses to simplify the engine bay/back of engine because I cannot imagine a scenario where I ever need a heater. Except for defogging, but doesn't AC do that, not the heater? So in this very limited situation, raising the rear could work, purely to let hot air out. I've ran the car at the track on a 35C day with the aircon on, and it doesn't overheat in that scenario so that's why I thought it was due to heat soak/heat buildup and not just general overheating under load. I had previously tried shrouding the radiator, changing my balancer to a non-underdriven one to spin the water pump more at idle too, and installing two more thermo fans on the other side of the radiator/AC condenser. (So I have 4 now, 2 pushing, 2 pulling from the rad) neither really helped in this very limited scenario. I don't know if the vents will, but visually seeing the heat steaming out of them did give me hope, not to mention the temperature of the vents was MUCH hotter than other areas of the bonnet. Enough that one of the paint guys was unsure as to whether paint would stick to it long term. I'm sure that will be fine also.
    • JustJap sell CF underskirts like that.
