Hi guys, i got pulled over in my skyline a few weeks ago for speeding, the copper didnt do anything on the day but about a week later i got a letter saying i had to take it into the EPA for a test or they will cancel the registration. Heres my problem, the car itself (4 door 32 gtst) Has a blow off valve, a fmic, and has been tuned by dr drift(the previous owner had it done). Now i know it runs as rich as hell, if i dont wash it for a week the back of the car gets a whole heap of black shit on it from the exhaust....and it does smoke a fair bit
I was wondering if anyone would know maybe how it was tuned? Somone had mentioned to me that he probably just reprogrammed the onboard computer? its got no super afc, or any other visible computer mods, and i need to know what i need done to it to get it to pass the EPA test. Will the bov pass the test or do i need to take it off?? If so where would i get the piece that i need to put in place of it?? I'm about to sell the car soon so even if i can get it tuned back to standard i wont mind.
I know alot of questions but i really need some advice on this from anyone who has maybe had the same problem or knows anyone who has.
If anyone has a contact for dr drift that would be helpfull to.
HELP!!!!!!!!
Thanks for any advice anyone can give me.
Edited by xxstuxx
First thing is DON'T PANIC!!, once you have done this test you'll understand how much of a waste fo time it is.
Is it a trip out to Macleod to the EPA or just a noise test??
A atmo-venting BOV will not pass! If it is, can you make it 'plumb back'?
I know from my 3 visit's that there's no need to panic about the EPA. Anything that you fail on the day they just issue you with a green sticker and then you have 28 days to fix whatever failed. I failed for noise the first time i went through, just came back 28 later and passed easy.
As for richness, just wash the car on the way out there...they only check the mixtures at idle. For me, they just had a good look under the bonnet, and just stuck their head inside the cabin for a look for any aftermarket stuff. Then they just put the probe thing in the exhaust while in idle. Then you just drive about 10m to a little rectangle on the ground where they test you for noise. If it's raining, they can't test for noise! I think i was there for about 8 mins.
(this was for a WRX too :) )
Thanks for your advice guys, i will take the bov off, can anyone point me in the direction of getting a plumback?? bit of a newbie when comes to my car :P I don't want to get ripped off, and i really only need it to pass this test so im not looking to spend heaps of $$ on it. As for the exhaust, not 100% sure what sort it is, and wether the cat is still in it, i think it may be a hi flow exhaust??(could be wrong remember im a noob) i just know it blows the smoke good and proper. i think i'll see what happens and if they fail ill just get a normal exhaust. thanks again for your advice.
Edited by xxstuxx
if its blowing smoke it could be possible u dont have a cat, if u take ur car into EPA and they c that u dont have a cat they will slap u with a huge fine!
best u get it checked out at any exhaust shop first
Also you can only have one intake mod, so you have to have a stock airbox on with your fmic. Unless you want to remove the fmic.
Thanks for the tip, it has a pod filter on it, can anyone give me some advice where to look for bits? as i'm going to need the plumback and the original air intake box (which i dont have), somewhere that i wont get ripped off as i got no idea what this stuff is worth.
Hi there,
Pods are fine, provided they are secured well.
Boost controllers and after-market computers are a problem
Obviously noise and pollution too
Hi there,
Yep... just stock exhaust and take the bov off...
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
