Another Price Drop. $13,000 with the wheels AS IS. $12,000 with standard R32 GTST wheels+good tyres. Get in and buy a nice looking and well-maintained car while you can. Petrol prices are dropping too so 2.0litre all the way!!! :spank:
Car is still for sale. Come on guys, one of the cleanest 32's going around. I just gave it a nice service... new plugs, filters, etc. New pod filter with cold air intake, new brake pads tomorrow. Car is well looked after
Edited by stawka
awesome looking 32. Just wandering if you could post up some pics of the engine bay and interior.
Cheers, Joel
Edited by jolz
  • 3 weeks later...
I cant actually post pics of the interior and engine bay as yet, my phone is playing up again. For those people that inquired about the car and i said "I will put in a new gearbox before i sell it because this one is stuffed"... Well, the job was done today. Car looks, sounds, and drives absolutely beautiful!
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
