Apexi Power FC...Again???
Guest RedLineGTR
This is for one of my mates,
He has a r33 auto gtst,
i am still not convinced that the power fc will not work on a auto i havent seen any proof (hardcopy) except for what people have said, no details on apexi sites usa and japan (translated) nor in the vechicle compatibilty list. I know people say that the auto trans need the stock ecu to get some details, would anyone be willing to plug there power fc (with min mods) in my auto, i assume that the auto trans would just not work, but everything else would be fine. Anyone shedding some light on the issue, i have heard there might be some development on the auto soarers but nothing decent.
Thanks
Thanks
https://www.sau.com.au/forums/topic/12368-apexi-power-fcagain/
Hi RedLineGTR, what I know.....
* The Auto ECU gets the road speed signal from the Engine ECU
* The Auto ECU gets the engine RPM signal from the Engine ECU
* The Auto ECU gets the throttle position signal from the Engine ECU
* The Auto ECU gets the engine load signal (fuel map position) from the Engine ECU
* The Auto ECU gets the engine water temperature signal from the Engine ECU
* These output signals are not in the same format as the input signals from the sensors themselves
* A Power FC does not output these signals
What I can deduce from what I know....
- The Auto ECU will not know the road speed, therefore it will not know when to change gear
- The Auto ECU will not know the engine RPM, therefore it will not know when to change gear
- The Auto ECU will not know the engine loading, therefore it will not know when to lock up the torque converter
- The Auto ECU will not know when the engine is not up to operating temperature (too cold), therefore it will allow too high an engine RPM.
Sorry, but I have no knowledge of how a Microtech or a Link sends their output signals to the Auto ECU.
What I would do...........
I would wire up the Power FC as a piggy back, such that it and the standard ECU received all of the input signals. But only the PFC ran the engine (ignition, injectors and boost control). That way the Auto ECU would still get the correct output signals from the Standard Engine ECU and the PFC would control the engine.
Hope that makes sense.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
