I'm looking to pull 420 - 450 rwhp on the R33 RB25. Got the basics, large fmic, highmount manifold, 4 inch dump and Apexi Power FC. Just looking at what else I need to add??
Fuel Pump Bosch 044 ??
550cc injectors ?? ( currently they are stock)
Turbo - GT3040 or GT3540 ??
Thanks in advance for the advice.
Wazza
https://www.sau.com.au/forums/topic/123697-looking-420-450rwhp-from-the-r33/
GT35 is required, boost late in the 4000rpm. 1st and 2nd gears will be mostly uselsss
Make sure you budget for the rebuild. No telling how long the motor will last @ that level.
carnt say that
maybe first but second isnt useless
Mate if you get the GT30 its more streetable
the GT35 you will have big TRACTION problems
These questions are for a mate who isnt a member (no puter).
I have told him to phone you re your GT3540 that is for sale.
The turbo is not only for sale
the whole package is
i will not be seperating the package as i will probly be stuck with parts that i carnt use on my next package that i just purchased
I found with my GT30 second really didnt give a lot of thrust, so it wasnt working hard. And thats without wheelspin.
So i would envisage the GT35 to be worse being its larger, comes on later and therefore would snowball
The gearing doesnt allow it to really load up unlike 3rd/4th which is good enough to allow a big GT35 to get into good movement.
these are the mods on mine:
G-Max Wheels rear: 18x9.5 with 265’s front: 18x8.5
Tein hight and rebound adjustable suspension
Full 3inch custom exhaust with Magic Cat and twin Mufflers
T04 turbo on X-Force highmount manifold
Turbosmart 48mm Pro-Gate wastegate
100mm think Front Mount Inter Cooler
Blitz blow off valve
Sard fuel pressure Regulator
Sard 550cc injectors
Walbro 500 horsepower fuel pump
Motec Enginge Management System
Exceedy 5 puck clutch
Pod air filter
Oil catch can
Thermo fan
Bonnet vents
Isotta Steering wheel
DBA 4000series sloted disks alround with braided lines
Braided fuel-line, blow-by, breather and radiator overflow hoses
New chrome radiator overflow tank
Gates Racing radiator hoses
Viper 790VX Pager car alarm
She is going through an RB30 bottom end conversion at the moment, but with those mods listed above, she was dynoed at 365rwhp at 14psi.
Wazza
might not be helpful but a
hks gt2835 pro s, rate at 420. would be able to make 400rwhp maybe alittle more and the lag of them isnt that bad, i find it comes on boost quickly and hard with min. wheel spin
of course you would need
550cc injectors or bigger (i would go 740cc they are only $50 more)
z32 afm
aftermarket ecu
bigger fuel pump
plus some suspension mods to help
get the power down (i highly recommened you buy an aftermarket lsd the stock one is shocking)
if the 2835 is too small, i would go for the gt3037 pro s
14psi/365 would be a fair effort in anyones stakes :P
Your graph is around 1.1bar... give or take so not quite 14psi... whats 1.1bar... i forget.
Someone will know what that is in PSI... i think 15.5 or 16?
Seems a tad laggy though, but similar to my old bucket T04 that i had moons ago.
Whats it like to drive on the street?
Really fun :P
The dyno was done before I bought the car so I really am going off what I have been told and know (which isn't much but I'm learning!)
Good luck with trying to get 400rwhp, but I think you're going to need a few more add on's than what you have, unless you want to go through an engine rebuild.
I don't know if this is going to help you at all, but these are the mods done to another R33 that was getting 472rwhp.
Engine
Top End
- RB25DET i6 24valve twin cam head (freshly rebuilt)
- Skyline GTR Cams
- Skyline GTR Valve springs
- Modified oiling system restricting flow to the head.
- Tomei 1.2mm metal head gasket
Bottom End
- RB30 3.0 litre turbo bottom end
- JE Forged Pistons (Dished) - HPC Coated
- Shot peened, crack tested, and strengthened rods
- Balanced & machined crank
- Blueprinted & balanced during assembly
- GTR Oil & Water pump
- Tomei Rod Bolts
- enlarged baffled Sump
Turbo, ECU & Fuel
- Trust Hybrid Turbo (T04R front wheel, back cut t66 rear, 360deg thrust bearing)
- Trust 45mm External WasteGate
- Trust Custom Tubular Exhaust Manifold
- Apexi PowerFC ECU + Hand Controller
- 16psi boost.
- Z32 300zx Air Flow Meter
- Aftermarket Jap 550cc Injectors (unknown brand)
Ancilleries
- 3" high flow cat, and a 3 1/2" trust system up to the turbo
- External 45mm Seperate pipe on the Wastegate into the exhaust just before the cat.
- Oil/Air Seperator with return line to the sump.
Unsure if he advertised on this forum, but here are two links to have a read of if you're interested in getting the same amount of hp:
http://www.performanceforums.com/forums/sh....php?t=67193992
http://www.performanceforums.com/forums/sh....php?t=67193482
Go the GT3540R, it is a great turbo and with the .82 exh housing that I have gives full boost at about 4800rpm. I have got 410.7rwhp at only 15psi, so it is easily capable of over 450rwhp with the right supporting mods. But a rebuild will be in order before winding the wick right up on boost
As R31Nismoid said, 1st gear is useless and second gear will spin on demand...you need a lot of rubber to get anything out of second...my 265's cant cope :P
I never remembered to ask ya Jason lol... how do you find it on the street?
Being it feeds in close to 5000rpm.
Where is your limiter set?
It is awesome to drive :P although it is slower than it was previously up to 4000rpm, but then the fun starts :PBJ:
The limiter is set at 8000rpm I think...I wouldn't mind putting in an RB26 crank to increase the displacement slightly, but as it is now, it still isn't that slow off boost
Cheers
JB
Thanks for all the replies and advice guys.
The mate has settled on a GT3040R - need to keep it streetable.
4000+ before power is not much fun and similar to what the current T70 is doing.
Been priced at $1745 does this sound reasonable?
Plus one second hand T70 for sale - slight scrapping noise from the exhaust turbine, still spinning, but not happy jan!!
Hey guys,
Here my current setup that dyno'd at 403whp on an RB25DET w/ garrett GT30R, avc-r is turned off and using a 1 bar spring on the external tial gate.
Internally stock, but i am in the process of buying tomei cams, and 1.2 headgasket.
My dyno is pretty close to phee's.
You guys think the cams would aid in boosting earlier?
RB25DET Motor Swapped from an 1994 R33
MINES Tuned 300ZX Z32 TTurbo ECU
Aeromotive Fuel Pressure Regulator
Aeromotive Liquid Filled Fuel Pressure Gauge
Greddy Hi Polished Intake Manifold
Greddy External Oil Catch Can
HKS SSQV BOV
HKS Type S Front Mount Intercooler
Garett GT30R Ball Bearing Turbo Hi Polished
Thermal Wrapped Turbo Blanket
Tial Wastegate 38mm
- Externally Dumped
Custom Top Mount Stainless Steel Exhaust Manifold
Kinetic Motorsports 550CC Injectors
Keeplabs Custom Billet Top Feed Fuel Rail
Keeplabs Custom 90mm Q45 Throttle Body
Keeplabs Custom One Piece Driveshaft
Keeplabs Custom Intercooler Piping
Keeplabs Custom 3” Downpipe (Heat Wrapped – 1 02 bung, 1 extra bung for Wideband)
Keeplabs Full AN Fittings, Stainless Braided Fuel System
3" Stainless Steel Catback Exhaust
- 3 Inch Straight Through From Turbo
Z32 AFM
Walbro 255 Fuel Pump
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
